Bring your sound everywhere. With bass you can feel, long total hours of battery life, and a secure, comfortable stick-closed design, the splash and dust resistant JBL Wave Beam are designed for your daily entertainment. Whether you're roaming city streets or relaxing on the beach, your hands-free stereo calls will always be crystal clear, while Smart Ambient technology keeps you aware of your surroundings. And when you need an extra boost, you can speed charge two additional hours of power in just 10 minutes.
JBL Deep Bass Sound
Get the most from your mixes with high-quality audio from secure, reliable earbuds with 8mm drivers featuring JBL Deep Bass Sound. -
Comfortable fit
The ergonomic, stick-closed design of the JBL Wave Beam fits so comfortably you may forget you're wearing them. The closed design excludes external sounds, enhancing the bass performance. -
Long hours of battery life with speed charging
With long hours of battery life in the earbuds and more in the case, the JBL Wave Beam provide all-day audio. And when you need more power, you can speed charge an extra two hours in just 10 minutes.
 - JBL Wave - true wireless earphones with mic
- Product Type
 - True wireless earphones - Bluetooth
- Recommended Use
 - Portable electronics
 - White
- Headphones Form Factor
 - Ear-bud
- Wireless Technology
 - Bluetooth
- Headphones Technology
 - Dynamic
- Bluetooth Version
 - Bluetooth 5.2
- Sound Output Mode
 - Stereo
- Sound Effects
 - Deep Bass
- Audio Specifications
 - Frequency Response 20 - 20000 Hz - Sensitivity 100 dB
- Impedance
 - 16 Ohm
- Product Type
 - True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
 - Earbud: 8.8 g , Charging case: 39.5 g
 - White
- Recommended Use
- Protection
 - Dust-resistant, IP54, water-resistant
Audio Output
 - Ear-bud
 - Dynamic
- Connectivity Technology
 - Wireless
 - Bluetooth
- Bluetooth Version
 - Bluetooth 5.2
- Bluetooth Profiles
 - Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
 - Stereo
- Sound Effects
 - Deep Bass
 - 20 - 20000 Hz
- Sensitivity
 - 100 dB
- Impedance
 - 16 Ohm
- Max Sound Pressure
 - 95 dB
- Diaphragm
 - 8 mm
Microphone
- Form Factor
 - Built-in
- Sensitivity
 - -38 dBV/Pascal
- Included Accessories
 - 3 pairs of ear tips (small, medium, large), USB-C charging cable, charging case (530 mAh)
- Cable Details
 - USB-C charge cable
- Battery
 - Headphone battery rechargeable - lithium polymer
- Included Qty
 - 2
- Capacity
 - 48 mAh
- Run Time (Up To)
 - 8 hours
- Run Time Details
 - Continuous playback: up to 8 hours , Continuous playback (with included charging case): up to 32 hours
- Recharge Time
 - 2 hours
