The JBL Tune 520BT headphones stream powerful JBL Pure Bass sound thanks to the 5.3 BT technology. Easy to use, these headphones provide long hours of pure pleasure and an extra 3 hours of battery with just 5 minutes of charge. Manage calls, sound and volume from the earcup, thanks to the convenient button control. If a call comes in while you are watching a video on another device, the JBL Tune 520BT seamlessly switch to your mobile, so you never miss a call. lightweight and comfortable even after hours of listening, the JBL Tune 520BT headphones fold flat in your backpack to follow you everywhere.
JBL Pure Bass sound
The JBL Tune 520BT feature the renowned JBL Pure Bass sound, the same that powers the most famous venues all around the world. -
Wireless Bluetooth 5.3 technology
Wirelessly stream high-quality sound from your smartphone without messy cords with the help of the Bluetooth technology. -
Customize your listening experience
The JBL Headphones App to tailor the sound to your taste with the EQ. Voice prompts in your language guide you through the Tune 520BT features. -
Long battery life and speed charge (5 mins = 3H)
For long-lasting fun, listen wirelessly for long hours and recharge the battery in as little as 2 hours with the convenient Type-C USB cable. A quick 5 minutes recharge gives you 3 additional hours of music. -
Hands-free calls with Voice Aware
Easily control your sound and manage your calls from your headphones with the convenient buttons on the ear-cup. Hear your voice while talking, with the help of Voice Aware. -
Multi-point connections
Allows you to effortlessly switch from one Bluetooth device to another. You can simply switch from a video on your tablet to a call on your mobile phone, so that you'll never miss a call. -
Lightweight, comfortable and foldable design
The lightweight materials and soft ear cushions with a padded headband make the headphones comfortable to wear for extended periods. The foldable design makes it convenient for you to carry your headphones anywhere and anytime you want music. -
Ask Siri or Hey Google
Siri or Hey Google is just a button away: activate the voice assistant of your device by pushing the multifunction button.
 - JBL TUNE 520BT - headphones with mic
- Product Type
 - Headphones - Bluetooth - wireless
 - Black
- Headphones Form Factor
 - On-ear
- Foldable
- Connectivity Technology
 - Wireless
- Wireless Technology
 - Bluetooth
- Headphones Technology
 - Dynamic
- Radio Frequency Range
 - 2.4 - 2.4835GHz
- Bluetooth Version
 - Bluetooth 5.3
- Sound Output Mode
 - Stereo
- Sound Effects
 - Pure Bass
- Audio Specifications
 - Frequency Response 20 - 20000 Hz - Sensitivity 102 dB
- Impedance
 - 30 Ohm
- Controls
 - Volume
- Intelligent Assistant
 - Google Assistant ready, Siri ready
- Product Type
 - 157 g
 - Black
Audio Output
 - On-ear
- Foldable
 - Dynamic
 - Wireless
 - Bluetooth
- Bluetooth Version
 - Bluetooth 5.3
- Bluetooth Profiles
 - Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
 - Stereo
- Sound Effects
 - Pure Bass
 - 20 - 20000 Hz
- Sensitivity
 - 102 dB
- Impedance
 - 30 Ohm
- Max Sound Pressure
 - 95 dB
- Diaphragm
 - 33 mm
- Adjustable Headband
Microphone
- Form Factor
 - Built-in
- Sensitivity
 - -29 dB
Remote Control
- Controls
 - Volume
Wireless Link
 - 2.4 - 2.4835GHz
- Modulation Type
 - GFSK, 8-DPSK, 4-DQPSK
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
 - Charging cable
- Cable Details
 - USB-C cable
- Battery
 - Headphone battery rechargeable - Lithium Ion
- Capacity
 - 450 mAh
- Run Time (Up To)
 - 57 hour(s)
- Run Time Details
 - Continuous playback (with 5 min charge): up to 3 hours
- Recharge Time
 - 2 hour(s)
