JBL Tune Beam True Wireless NC Earbuds ANC/Dual Purple
Quicklinx: HWXQWS00 Mfr#: JBLTBEAMPUR
Type: Earbuds
Connectivity: Wireless
Colour: Purple
Colours:
10 In Stock
£65.84 ex VAT
£79.00 inc VAT
Express delivery Order within the next 7 hours for delivery on Monday
Tackle your day one song at a time with the JBL Tune Beam. These true wireless earbuds give you long hours of exceptional JBL Pure Bass Sound, while the ergonomic, water and dust resistant design gives you all-day comfort in any weather. A simple touch allows you to manage and enjoy perfect calls anywhere, without ambient noises. And with Active Noise Canceling and Smart Ambient technology, you choose whether you want to tune out the world or engage with your surroundings. The stick-closed design ensures a secure fit, isolation from outside noise for better sound performance. Best of all, the JBL Headphones App lets you personalize your entire listening experience. Stay connected to your world, your way.
  • JBL Pure Bass Sound
    Smartly designed 6 mm drivers enhanced by the stick's form factor deliver JBL's Pure Bass Sound, so you'll feel every pulsing beat.
  • Bluetooth 5.3 with LE audio support
    Thanks to the next generation Bluetooth technology, the JBL Tune Beam earbuds stream audio with low power consumption at high quality. Plus, BT 5.3 allows you to stream synchronized audio independently to each earbud, so that you can use either or both earbuds. Or you can share your video or music content with a friend wearing headphones, as BT 5.3 lets you seamlessly stream audio to multiple listeners.
  • Active noise canceling with smart ambient
    Hear more of what you want, less of what you don't. Active Noise Canceling technology lets you minimize audio distractions. With Ambient Aware, you can tune into your surroundings at any time so that you feel safer when you're out in the world, while TalkThru lets you stop for a quick chat without having to remove your headphones.
  • 4-mic technology for crisp, clear calls
    Enjoy hassle-free, hands-free calls in stereo. The Tune Beam are equipped with dual microphones, so you'll always be heard with perfect clarity. Never hesitate to take or make a call again. And with VoiceAware, you can choose how much of your own voice to hear by controlling the amount of mic input routed back into your earbuds.
  • Water and dust resistant
    Don't be deterred by bad weather. Thanks to IP54 water resistance and dust proofing, there isn't a workout or downpour the Tune Beam can't handle.
  • All-day fit and comfort
    Never be without your music. The stick-closed Beam design ensures good isolation sealing from the outside noises for a great sound performance and a secure, comfortable fit. The oval tube design snuggly adapts to your ear's ergonomics, ensuring a comfortable fit, natural blocking of outside noises and better sound quality.
  • JBL headphones App
    The JBL Headphones App lets you enjoy your music your way. Customize your listening experience and the touch control gestures, find your earbuds, control the environmental noise and the Smart Audio & Video modes. Download the App for free and discover how much more you can do.
JBL TUNE Beam - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Purple
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Sound Effects
Pure Bass
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 97 dB
Impedance
16 Ohm
Noise Isolating
Microphones Included
4
True wireless earphones - Bluetooth - wireless
Dimensions & Weight Details
Charging case: 52.2 g , Earbud: 7.2 g
Purple
Recommended Use
Protection
Dust-resistant, water-resistant
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Sound Effects
Pure Bass
Noise Isolating
Active Noise Cancelling Technology
Smart Ambient
Frequency Response
20 - 20000 Hz
Sensitivity
97 dB
Impedance
16 Ohm
Diaphragm
6 mm
Microphone
Built-in
4
Tracking
Sensors
Touch control
3 pairs of ear tips (small, medium, large), charging cable
IP54
Rechargeable
Run Time (Up To)
48 hour(s)
Run Time Details
Continuous playback (noise cancelling OFF): up to 12 hours , Continuous playback (noise cancelling ON): up to 10 hours , Continuous talk (noise cancelling OFF): up to 6.6 hours , Continuous playback (with included charging case): up to 48 hours
Recharge Time
2 hour(s)
Type: Earbuds
Colour: Purple
Brand: JBL
