The JBL Tune 720BT headphones stream powerful JBL Pure Bass sound thanks to the 5.3 BT technology. Easy to use, these headphones provide long hours of pure pleasure and an extra 3 hours of battery with just 5 minutes of charge. The JBL Headphones App and customize your sound through the EQ, while Voice Prompts guide you through the headphones features. Manage calls, sound and volume from the earcup, thanks to the convenient button controls. If a call comes in while you are watching a video on another device, the JBL Tune 720BT seamlessly switch to your mobile, so you never miss a call. Lightweight and comfortable even after hours of listening, the JBL Tune 720BT headphones fold flat in your backpack to follow you everywhere.
JBL Pure Bass sound
The JBL Tune 720BT feature the renowned JBL Pure Bass sound, the same that powers the most famous venues all around the world. -
Wireless Bluetooth 5.3 technology
Wirelessly stream high-quality sound from your smartphone without messy cords with the help of the aBluetooth technology. -
Customize your listening experience
Download the free JBL Headphones App to tailor the sound to your taste with the EQ. Voice prompts in your language guide you through the Tune 720BT features. -
Multi-point connections
Allows you to effortlessly switch from one Bluetooth device to another. You can simply switch from a video on your tablet to a call on your mobile phone, so that you'll never miss a call. -
Lightweight, comfortable and foldable design
The lightweight materials and soft ear cushions with a padded headband make the headphones comfortable to wear for extended periods. The foldable design makes it convenient for you to carry your headphones anywhere and anytime you want music. -
Detachable audio cable
Flat battery? Extend the fun endlessly with the included audio cable. -
Hands-free calls with Voice Aware
Easily control your sound and manage your calls from your headphones with the convenient buttons on the ear-cup. Hear your voice while talking, with the help of Voice Aware. -
Long battery life and speed charge (5 mins = 3H)
For long-lasting fun, listen wirelessly for long hours and recharge the battery in as little as 2 hours with the convenient Type-C USB cable. A quick 5-minute recharge gives you 3 additional hours of music.
 - JBL TUNE 720BT - headphones with mic - 3.5 mm jack
- Product Type
 - Headphones - Bluetooth - wireless, wired - 3.5 mm jack
- Recommended Use
 - Portable electronics
 - Black
- Headphones Form Factor
 - Full size
- Foldable
- Connectivity Technology
 - Wireless, wired
- Wireless Technology
 - Bluetooth
- Headphones Technology
 - Dynamic
- Bluetooth Version
 - Bluetooth 5.3
- Sound Output Mode
 - Stereo
- Sound Effects
 - Pure Bass
- Audio Specifications
 - Frequency Response 20 - 20000 Hz - Sensitivity 101 dB
- Impedance
 - 32 Ohm
- Controls
 - Volume, play/pause, next/previous track, voice assistant, answer/end, microphone on/mute, power on/off
 - 1-year warranty
- Product Type
 - 220 g
 - Black
- Recommended Use
 - Multipoint Pairing, VoiceAware
Audio Output
 - Full size
- Foldable
 - Dynamic
 - Wireless, wired
 - Bluetooth
- Bluetooth Version
 - Bluetooth 5.3
- Bluetooth Profiles
 - Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP)
- Sound Output Mode
 - Stereo
- Sound Effects
 - Pure Bass
 - 20 - 20000 Hz
- Sensitivity
 - 101 dB
- Impedance
 - 32 Ohm
- Max Sound Pressure
 - 95 dB
- Diaphragm
 - 40 mm
- Adjustable Headband
Microphone
- Form Factor
 - Built-in
- Sensitivity
 - -40 dB
Remote Control
- Controls
- Connector Type
 - Headphones (mini-phone stereo 3.5 mm)
Cable
- Detachable Cable
- Cable Length
 - 1.2 m
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
 - USB-C charging cable, audio cable
- Cable Details
 - USB-C charge cable , Audio cable - detachable - 1.2 m
- Battery
 - Headphone battery rechargeable - Lithium Ion
- Capacity
 - 500 mAh
- Run Time (Up To)
 - 76 hour(s)
- Run Time Details
 - Continuous playback (with 5 min charge): up to 3 hours , Continuous playback (Bluetooth ON): up to 76 hours , Continuous talk: up to 45 hours
- Recharge Time
 - 2 hour(s)
 - Limited warranty - 1 year
