Level up with powerful JBL Quantum Duo PC gaming speakers. Go deeper into the action with pitch-perfect sound and unique lighting effects. Easily pinpoint incoming fire, hear enemies creeping up on you and feel the roar of explosive action. With JBL proprietary gaming surround sound and Dolby Digital in a cool, distinctive design. Never miss a step, shot or jump with exposed drivers and tweeters for incredible sound clarity. With the different color presets and lighting patterns to personalize your setup, gaming has never felt more real.
JBL QuantumSOUND signature
From the tiniest footsteps to the loudest explosion, JBL QuantumSOUND Signature makes every scene epic and every gamer more competitive. The high excursion 2.5" neodymium drivers and tweeters deliver a sound curve tuned by JBL audiologists and specifically designed for gaming. The signature surround sound technology, together with Dolby digital, creates the realistic soundstage. Be fully devoted in the game and win the game as it allows you to hear every enemies coming by. -
Experience every detail
You'll never miss a bullet, a crunch in the gravel or a moan of the undead with the incredible sound clarity and powerful, intense bass. Delivered by exposed drivers and rear facing bassports. -
Customizable lights
Supercharge your gaming rig with cool lighting effects that take you deeper into the action. JBL Quantum Duo PC gaming speakers come with different colour presets and lighting patterns. Set the mood easily with the lighting control button. -
See the beat
By syncing lights to the beat, audio sync lets you see your favourite tracks as well as hear them. Visualise your music and choose your vibe with the Wave or Flow lighting patterns. Or try the Solid setting in any colour you like. -
Bluetooth for wireless music streaming
Enjoy wireless audio streaming with built-in Bluetooth. -
Plug-and-Play with intuitive controls
No additional setup required. Plug-and-Play JBL Quantum Duo PC speakers enhance any gaming experience. Intuitive controls mean you can change volume and lighting effortlessly, keeping you focused and in the moment. -
Compatible with any gaming system
Connect JBL Quantum Duo PC gaming speakers effortlessly to any system via audio-in and USB. Fully compatible with PC, Mac, Windows and gaming consoles.
- JBL Quantum Duo - speakers - for PC - wireless
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Nominal Output Power (Total)
- 20 Watt
- Frequency Response
- 60 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Black
- Built-in Decoders
- Dolby Digital
- 8.9 cm x 17.6 cm x 21 cm
- 2.8 kg
- 1-year warranty
- Product Type
- Speakers - for PC
- Light
- Multicolour LED light
- Enclosure Colour
- Black
Speaker System
- System Components
- 2 speakers
- Speaker Type
- 2-way - active
- Audio System Continuous Power (Total)
- 20 Watt
- 60 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Amplifier
- Integrated
- Bluetooth 4.2
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Built-in Decoders
- Dolby Digital
- Controls
- Volume
Speaker System Details
- Driver Details
- Speaker: woofer driver - 2.5" - neodymium , Speaker: tweeter driver - 0.75"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Audio cable, USB cable
- Power Source
- Integrated power supply
- 8.9 cm
- 17.6 cm
- 21 cm
- 2.8 kg
- Limited warranty - 1 year
