Stay one step ahead of the competition. The JBL Quantum 800 headset gives you the edge with accurate spatial audio positioning, lossless 2.4GHz, and Bluetooth dual-wireless capability, Active Noise Cancelling, memory-foam comfort, and a long battery life. Designed for total immersion, JBL QuantumSOUND Signature gives you a true audio advantage in battle. The microphone delivers clear multiplayer interactions, with a DISCORD-certified game-chat system, also compatible with TeamSpeak, and more. An ergonomic design with leather-wrapped, memory foam cushions keeps you comfortable for hours. The JBL Quantum 800 headset helps you level up, whether you're a seasoned pro or new to the game.
Dual wireless-equipped for lossless audio freedom
Get up for a snack without ever taking off your headset. JBL Quantum 800 headsets are gaming-grade, lossless 2.4GHz, and Bluetooth 5.0 dual wireless audio equipped, complete with a 14-hour battery life. -
Play even longer
The lightweight, ventilated headband, and premium leather-wrapped, memory foam ear cushions are designed for even the longest gaming sessions. -
Active Noise Cancelling tuned for gaming
Designed for gaming environments, the Active Noise Cancelling system eliminates unwanted background sounds so you can stay fully engaged in combat without distractions. -
Be heard with the voice focus boom mic
Echo-cancelling technology makes sure you're heard loud and clear when rallying the troops or opponents. Or not. The Quantum 800 features a 2-way mute possibility. Just flip up the adjustable boom mic to mute your voice or press the button built into the ear cup. -
Compatible with all gaming platforms
Created for PC gaming, JBL Quantum 800 headset is also compatible with Xbox, PlayStation, Nintendo Switch, Mobile, Mac, and VR. -
Powerful JBL QuantumENGINE software suite customization
JBL's unique JBL QuantumENGINE PC software powers the immersive surround sound. Select your preferred surround sound settings and personalise your JBL Quantum 800 gaming headset from a user-friendly dashboard, creating separate profiles and RGB effects, and modifying microphone settings. You can also adjust the equaliser or choose from 6 presets. -
Audio precision, designed for gamers
Get the game's most immersive and accurate surround sound. JBL QuantumSURROUND puts you at the centre of an immersive experience, allowing you to up your game and triumph over the competition. Also equipped with DTS headphone:X v2.0.
- JBL Quantum 800 - headset
- Product Type
- Headset - Bluetooth / 2.4 GHz radio frequency - wireless
- Additional Functions
- LED backlight
- Black
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- DTS Headphone:X 2.0
- Audio Specifications
- Frequency Response 20 - 40000 Hz - Sensitivity 95 dB
- Impedance
- 32 Ohm
- Max Input Power
- 30 mW
- Active Noise Canceling
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- 1-year warranty
- Product Type
- LED backlight
- 410 g
- Black
- Earpad Material
- Memory foam
Audio Output
- Full size
- Dynamic
- Wireless
- Bluetooth Version
- Bluetooth 5.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Stereo
- Sound Effects
- 20 - 40000 Hz
- Max Input Power
- 30 mW
- Sensitivity
- 95 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 93 dB
- Diaphragm
- 50 mm
- JBL Quantum SURROUND, QuantumSOUND Signature
Microphone
- Boom
- Uni-directional
Wireless Link
- Modulation Type
- GFSK, DQPSK
- Connector Type
- Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Wind shield, USB dongle
- Cable Details
- Audio cable
- Battery
- Headset battery rechargeable - Lithium Ion
- Capacity
- 1300 mAh
- Run Time (Up To)
- 14 hour(s)
- Recharge Time
- 2 hour(s)
- 1-year warranty
