Bring the party with the portable power of JBL PartyBox 100. Ignite the night. Pick the perfect light show or let the music choose the mood. Mix it up. Pop in a playlist from your USB stick or stream from a Bluetooth-compatible device. Rock out on the fly with mic and guitar inputs. Find your sweet spot. Mount your speaker on a pole and immerse the room in dynamic JBL sound. Plug your speaker into the wall to keep the tunes flowing.
Power to the party
Kick out the hottest jams in town. JBL PartyBox 100 thumps out 160 Watts of that pounding JBL signature sound. Start the party whenever and wherever you need. -
Light up your party
Boost your party with an epic light show. Choose from several RGB LED light patterns or let the colors groove to the music for a next-level audio-visual party. -
Plug in and play
Have mic, will sing. Have guitar, will shred. Just plug into your speaker, take to the stage and rock that party like there's no tomorrow. -
Stream seamlessly with Bluetooth
It's easy to keep the music flowing. Simply connect to your smartphone, tablet, or favorite online service via any Bluetooth-compatible device for uninterrupted wireless streaming. -
Playlists made easy
Personalize your party. Build your ultimate party sounds from the ground up. Just make your playlist, pop it on a USB-capable thumb drive and slip it into your speaker.
- JBL PartyBox 100 - speaker - wireless
- Product Type
- Speaker
- Media Content Source
- USB-host
- Speaker Type
- 2-way - active
- Frequency Response
- 45 - 18000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - 45 - 18000 Hz - 2-way - active
- Sound Effects
- Bass Boost
- Power
- AC 120/230 V / DC 12 V
- Battery
- Speaker battery rechargeable - Lithium Ion
- 28.8 cm x 29 cm x 55.1 cm
- 9.7 kg
- 1-year warranty
- Product Type
- Speaker
- USB-host
- Design Features
- LED effects
Speaker System
- Speaker Type
- 2-way - active
- 45 - 18000 Hz
- Amplifier
- Integrated
- Sound Effects
- Bass Boost
- Bluetooth
- Additional Features
- True Wireless Stereo (TWS) system
Speaker System Details
- Speaker Details
- Speaker - 45 - 18000 Hz CFR - 2-way - active
- Driver Details
- Speaker: 2 x woofer driver - 5.25" , Speaker: 2 x tweeter driver - 2.25"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Audio line-out (mini-phone stereo 3.5 mm) , Microphone (phone 6.3 mm) , Guitar audio input (phone 6.3 mm) , USB (4 PIN USB Type A)
- Power Source
- Battery, Integrated power supply
- Voltage Required
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 2500 mAh
- Run Time (Up To)
- 14 hour(s)
- Recharge Time
- 5 hour(s)
- 28.8 cm
- 29 cm
- 55.1 cm
- 9.7 kg
- Shipping Width
- 35.6 cm
- Shipping Depth
- 35.2 cm
- Shipping Height
- 66.4 cm
- Shipping Weight
- 11.3 kg
- Limited warranty - 1 year
