JBL Live Pro 2 TWS ANC - Silver
Quicklinx: HWXGWS00 Mfr#: JBLLIVEPRO2TWSSIL
Type: Headphones
Colours:
£108.33 ex VAT
£129.99 inc VAT
Stay in the groove all day long with stylish companions for work and play. JBL Live Pro 2 earbuds deliver hours of incredible JBL Signature Sound, speed charging, and Qi-compatible wireless charging for when your batteries need a boost. True Adaptive Noise Canceling eliminates distractions to give you totally immersive audio, while Smart Ambient keeps you alert to your surroundings. The stick closed design with Oval Tubes ensure better noise cancelation and enhanced audio quality for those who prefer a cleaner aesthetic. Got something to say? Make clear, perfect calls with 6 beamforming mics or access your preferred voice assistant for seamless handsfree control and connection wherever life's adventures take you.
  • JBL Signature Sound
    Nothing beats incredibly clear music and calls from 11 mm dynamic drivers powered by JBL Signature Sound.
  • True Adaptive Noise Canceling with Smart Ambient
    True Adaptive Noise Canceling automatically adjusts to your surroundings, eliminating distractions for better sound wherever you are. Or use Smart Ambient when you need to focus on your environment, all without removing your earbuds.
  • Hours of playback with wireless charging
    Never miss a moment with hours of Qi-compatible battery life. Need a boost? Just 15 minutes of Speed Charge gives you another four hours of playtime - fast.
  • 6 mics for perfect calls with zero noise
    Six beamforming microphones reduce wind and noise interference so your words always come through loud and clear. And with VoiceAware, you can choose how much of your own voice to hear by controlling the amount of mic input routed back into your earbuds.
  • IPX5 water-resistant
    Whether you're hitting the gym or caught in the rain, you won't have to worry. IPX5 means JBL Live Pro 2 headphones are water-resistant.
  • Dual Connect and Sync with Multi-Point connection
    Phone call in the middle of your favorite show? No problem. With Multi-Point connection, you can quickly and easily switch your headphone input from one Bluetooth device to another. You'll also enjoy quick, effortless pairing with any Android device as you shift between mono and stereo and your left, right, or both earbuds.
JBL LIVE PRO 2 TWS - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Silver
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
Signature Sound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 105 dB
Impedance
16 Ohm
Active Noise Canceling
Microphones Included
6
Intelligent Assistant
Google Assistant, Alexa
1-year warranty
True wireless earphones - Bluetooth - wireless
Dimensions & Weight Details
Earphone: 4.8 g , Charging case: 48.4 g
Silver
Recommended Use
Touch control
Protection
IPX5, waterproof, sweat-resistant
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.2
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Sound Effects
Signature Sound
Active Noise Cancelling Technology
Frequency Response
20 - 20000 Hz
Sensitivity
105 dB
Impedance
16 Ohm
Diaphragm
11 mm
Voice control, Google Fast Pair, Dual Connect + Sync Technology, Smart Ambient
Microphone
Built-in
6
Internet of Things (IoT)
3 sizes of soft in-ear plugs
Cable Details
USB-C charge cable
IPX5
Headphone battery rechargeable - wireless charging
Wireless Charging Standards
Qi
Included Qty
2
Run Time (Up To)
10 hour(s)
Run Time Details
Continuous playback: up to 10 hours , Continuous playback (with included charging case): up to 40 hours
Recharge Time
2 hour(s)
Limited warranty - 1 year
Type: Headphones
Brand: JBL
