JBL Live 670NC headphones deliver powerful JBL Signature Sound in a comfortable on-ear headband style. When you're deep in your flow, True Adaptive Noise Canceling with Smart Ambient technology keeps you free from distractions. Then, when you want to keep an ear open to the world around you, you can stay aware as you continue listening to your favorite playlist - or even have a conversation without taking the headphones off. Easily access your preferred voice assistant with a tap on the ear cup to cue up a song, text your friend, check the weather, and much more. You'll enjoy 65 hours (50 hours with BT+ANC on) of music streaming. And if you still need more, a 5-minute speed charge gets you another four hours. The JBL Live 670NC can connect with two Bluetooth devices simultaneously, so you'll never have to miss a call, even if you're watching a movie on your tablet.
                JBL Signature Sound and surround soundAlong with powerful JBL Signature Sound, the 40 mm drivers offer immersive JBL Spatial Sound that turns any stereo content from any device into virtual surround sound.
                Bluetooth 5.3 with LE audio supportedWirelessly stream high-quality sound even at lower bit rates with the help of the Bluetooth technology. Audio Mode gets you the best available sound, while Video Mode makes sure the sound and visuals of your movies and games are always in sync.
                True Adaptive Noise Canceling with Smart AmbientWith four noise-sensing mics, True Adaptive Noise Canceling means zero distractions, whether it's time to focus on your studies or get lost in the groove. And if you want to hear the world around you without removing your headphones, Smart Ambient sharpens the sounds of your surroundings.
                Up to 65 hours of battery life and speed chargeFor long-lasting fun, listen wirelessly for up to 50 hours and recharge the battery in as little as 2 hours with the convenient Type-C USB cable. And if you're in a hurry, a quick 5-minute recharge gives you 4 additional hours of music.
                Auto play and pauseTake the headphones off, the music stops. Put it back on, the music starts again. It genuinely couldn't be simpler.
                Multi-point connectionEffortlessly switch from one Bluetooth device to another. Jump from a video on your tablet to a call on your mobile phone, and never miss a moment.
                Seamless connectivity with any deviceWhether you're using an Android or Windows device, it's easy to set up your headphones to automatically pair with it whenever it's nearby.
                2 beamforming microphones for callsYour friends, family, and co-workers will hear every word you say - even if you're outside and it's windy.
                Comfort-fit fabric headband and carrying pouchSoft ear cushions and a textured, fabric headband in earthly shades make these headphones comfortable and unique. And when you do take them off, they have a comfy and protective place to live that's easy to pull out of your bag.
- JBL LIVE 670NC - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless, wired - 3.5 mm jack
- Recommended Use
- Portable electronics, computer
- White
- Headphones Form Factor
- On-ear
- Foldable
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.3
- Sound Output Mode
- Stereo
- Sound Effects
- Surround Sound, Signature Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 100 dB
- Impedance
- 32 Ohm
- Active Noise Canceling
- Microphone Operation Mode
- Beamforming
- Microphones Included
- 2
- Controls
- Mute, volume, answer/end, play/pause, next/previous track, voice assistant, ANC mode
- Intelligent Assistant
- Google Assistant, Alexa
- Product Type
- 219 g
- White
- Recommended Use
- Multipoint Pairing
Audio Output
- On-ear
- Foldable
- Dynamic
- Wireless, wired
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Sound Effects
- Active Noise Cancelling Technology
- True Adaptive Noise Canceling
- 20 - 20000 Hz
- Sensitivity
- 100 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 95 dB
- Diaphragm
- 40 mm
- TalkThru technology, Ambient Aware, Smart Ambient
- Audio Output Details
- Bluetooth mode - 20 - 20000 , AUX mode - 20 - 40000
Microphone
- Form Factor
- Built-in
- Beamforming
- 2
- Sensitivity
- -38 dBV/Pascal
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone stereo 3.5 mm)
Cable
- Detachable Cable
- Cable Length
- 2 m
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- Carrying pouch, audio cable, USB-C charging cable
- Cable Details
- USB-C charge cable - detachable , Audio cable - detachable - 2 m
- Battery
- Headphone battery rechargeable - Lithium Ion
- Capacity
- 850 mAh
- Run Time Details
- Continuous playback (noise cancelling ON / Bluetooth): up to 50 hours , Continuous playback (noise cancelling OFF / Bluetooth): up to 65 hours , Continuous playback (noise cancelling ON / cable connection): up to 40 hours , Continuous talk (noise cancelling ON): up to 28 hours , Continuous talk (noise cancelling OFF): up to 33 hours
- Recharge Time
- 3 hour(s)
- 45 °C
