The JBL Link 300 is a voice-activated speaker with Wi-Fi and Bluetooth enabled that delivers incredible room-filling sound from a compact design. It has the Google Assistant built-in. It's your own personal Google. Always ready to help. You can ask it questions. And tell it to do things. The more you use it, the more useful it gets. Just start with "Ok Google" - a simple voice request triggers your JBL Link 300 to play music, podcasts or radio from services like Google Play Music, Spotify, Pandora and more. To amplify your party, speakers with Chromecast built-in can be grouped together to enjoy the same song in every room.
Get help from your Google Assistant
JBL Link 300 has the Google Assistant built-in. It is your own personal Google. Always ready to help. -
Hands-free voice control
Far-field voice recognition allows for easy hands-free operation. Ask questions across the room and the JBL Link 300 will respond. -
Simple setup with the Google Home app on iOS and Android
With the free Google Home app on iOS and Android, you can easily setup and manage your JBL Link 300. -
Chromecast built-in
Lets you instantly stream your favorite music, radio, or podcast from your mobile device to your speakers. -
24 bit/96kHz high quality sound, powered by the cloud
Chromecast streams directly from the cloud, so you get the highest sound quality. Enjoy crystal clear sound exactly the way the artist intended. -
Multi-room playback across speakers that have Chromecast built-in
Easily set up your system and control multi-room playback with the Google Home app. A step by step guide allows you to quickly start streaming your music. -
2.4/5GHz Wi-Fi connection network support
Support both 2.4GHz and 5 GHz Wi-Fi connection, resulting in a faster, robust and more stable wireless connection. -
Wireless Bluetooth streaming
Wirelessly stream high-quality sound from your smartphone or tablet. -
Room-filling sound
A compact design equipped with high performance JBL transducers to deliver incredible room filling sound.
- JBL LINK 300 - smart speaker
- Product Type
- Smart speaker
- Localisation
- United Kingdom
- Speaker Type
- 2-way - active
- Continuous Power
- 50 Watt
- Frequency Response
- 55 - 22000 Hz
- Bluetooth, IEEE 802.11b/g/n/ac
- Platform
- Google Home
- Intelligent Assistant
- Google Assistant - direct
- Streaming Services
- Pandora, Spotify, Google Play Music, Chromecast
- Audio Formats
- WAV, MP3, FLAC, AAC-LC, LPCM, HE-AAC, OPUS, Vorbis
- Speaker Details
- Speaker - stereo x 2 - 25 Watt - 55 - 22000 Hz - 2-way - active
- Black
- 23.6 cm x 15.4 cm x 13.4 cm
- 1.7 kg
- Product Type
- Smart speaker
- Hands-Free Function
- Microphone
- Enclosure Colour
- Black
- Localisation
- United Kingdom
Speaker System
- Speaker Type
- 2-way - active
- Continuous Power
- 50 Watt
- 55 - 22000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Maximum Sampling Rate Supported
- 96 kHz
- Multiroom
- Amplifier
- Integrated
- Bluetooth 4.2, IEEE 802.11b/g/n/ac
- Internet Streaming Services
- Audio Formats
- Controls
- Voice control
Internet of Things (IoT)
- Platform
- Google Home
- Communications Type
- Cloud
- Google Assistant
- Voice Control
- Direct
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 25 Watt - 55 - 22000 Hz CFR - 2-way - active
- Driver Details
- Woofer driver - 3.5" , Tweeter driver - 0.79"
- Included Accessories
- Power adapter, charging cable
- Power Source
- AC power adapter
- 23.6 cm
- 15.4 cm
- 13.4 cm
- 1.7 kg
