Enjoy hassle-free, hands-free calls in stereo. The Tune Flex are equipped with 4 microphones, so you'll always be heard with perfect clarity. Never hesitate to take or make a call again. And with VoiceAware, you can choose how much of your own voice to hear by controlling the amount of microphone input routed back into your earbuds.
JBL pure bass sound
Smartly designed 12 mm drivers enhanced by the stick form factor deliver JBL's pure bass sound so you'll feel every pulsing beat. -
Active noise canceling with smart ambient
Hear more of what you want, less of what you don't. Active Noise Canceling technology with 2 microphones lets you minimize audio distractions. With Ambient Aware, you can tune into your surroundings at any time so that you feel safer when you're out in the world, while TalkThru lets you stop for a quick chat without having to remove your headphones. -
4 microphones for perfect calls
Enjoy hassle-free, hands-free calls in stereo. The Tune Flex are equipped with 4 microphones, so you'll always be heard with perfect clarity. Never hesitate to take or make a call again. And with VoiceAware, you can choose how much of your own voice to hear by controlling the amount of microphone input routed back into your earbuds. -
Water resistant and sweatproof
Don't be deterred by bad weather. Thanks to lPX4 water resistance and sweat proofing, there isn't a workout or downpour the Tune Flex can't handle. -
All-day fit and comfort
Never be without your music. The stick open design ensures comfort without pressure and natural sound awareness. Additional sealing tips in 3 sizes together with the sealing ear tip mode in the app allow you to create environmental sound sealing without compromising the light, sleek design of these earbuds.
 - JBL TUNE Flex - true wireless earphones with mic
- Product Type
 - True wireless earphones - Bluetooth
- Recommended Use
 - Portable electronics
 - Black
- Headphones Form Factor
 - Ear-bud
- Wireless Technology
 - Bluetooth
- Headphones Technology
 - Dynamic
- Bluetooth Version
 - Bluetooth 5.2
- Sound Output Mode
 - Stereo
- Sound Effects
 - Pure Bass
- Audio Specifications
 - Frequency Response 20 - 20000 Hz - Sensitivity 110 dB
- Impedance
 - 32 Ohm
- Active Noise Canceling
- Product Type
 - True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
 - Charging case: 5.15 cm x 2.93 cm x 4.7 cm / 38.6 g , Earbud: 2.05 cm x 2.02 cm x 3.49 cm / 4.8 g
 - Black
- Recommended Use
Audio Output
 - Ear-bud
 - Dynamic
- Connectivity Technology
 - Wireless
 - Bluetooth
- Bluetooth Version
 - Bluetooth 5.2
- Bluetooth Profiles
 - Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
 - Stereo
- Sound Effects
 - Pure Bass
- Active Noise Cancelling Technology
 - Smart Ambient
 - 20 - 20000 Hz
- Sensitivity
 - 110 dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 12 mm
Microphone
- Form Factor
 - Built-in
- Sensitivity
 - -38 dBV/Pascal
- Included Accessories
 - USB-C charging cable, 3 sizes of earhooks, charging case (570 mAh)
- Cable Details
 - USB-C charge cable
 - IPX4, GFSK, p/4 QPSK, 8DPSK
- Battery
 - 2 x headphone battery rechargeable - lithium polymer
- Included Qty
 - 2
- Capacity
 - 55 mAh
- Run Time (Up To)
 - 4.5 hours
- Run Time Details
 - Continuous playback: up to 32 hours , Continuous playback: up to 4.5 hours , Continuous playback (ANC OFF / Bluetooth): up to 8 hours , Continuous playback (ANC ON / Bluetooth): up to 6 hours , Continuous playback (with included charging case): up to 18 hours
- Recharge Time
 - 2 hour(s)
