JBL Go portable speaker - Black
Quicklinx: DBDSWS00 Mfr#: JBLGOBLK
Colours:
JBL Go is a full-featured, great-sounding, great-value portable speaker.
  • Audio cable input
    Don't worry if there's no Bluetooth, plug the audio cable into the speaker and enjoy your music all the same.
  • Wireless Bluetooth streaming
    Wirelessly stream high-quality sound from your smartphone or tablet.
  • Speakerphone
    Take calls from your speaker with a touch of a button - crystal clear thanks to the noise free speakerphone.
JBL Go - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Amplifier
Integrated
Bluetooth
Power Options
USB charging
Speaker battery rechargeable
8.27 cm x 3.08 cm x 6.83 cm
Hands-Free Function
Enclosure Colour
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth
Controls
Power on/off, volume, call answer
Additional Features
Noise filter, voice echo cancellation, integrated strap hook
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Power Source
Options
USB charging
Rechargeable
Run Time (Up To)
5 hour(s)
8.27 cm
3.08 cm
6.83 cm
