Ultra-portable JBL Pro Sound with punchier bass
Don't let its little size fool you. The JBL Go 4 packs a serious musical punch, delivering big JBL Pro Sound with punchy bass. Your friends won't believe how much great JBL Pro Sound comes out of such a small speaker. -
Up to 7 hours of playtime plus 2 hours with Playtime Boost
Don't sweat the small stuff like charging your battery. JBL Go 4 gives you up to 7 hours of playtime on a single charge. Simply tap Playtime Boost to prolong the playtime, adding up to 2 hours to your battery life. It tunes and optimizes the performance for louder and crisper sounds. -
Waterproof and dustproof
The JBL Go 4's IP67 waterproof and dustproof rating ensures this portable speaker can handle almost any environment, from a poolside party to a seaside picnic. -
Multi-speaker connection by Auracast
Want even bigger JBL Pro Sound? Pair two Go 4s for stereo sound, or wirelessly connect multiple JBL Auracast-enabled speakers using Auracast for even bigger sound. -
Made in part with recycled materials
The JBL Go 4 incorporates post-consumer recycled plastic and fabric for the speaker grille.
- JBL Go 4 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Dustproof, waterproof
- Speaker Type
- Active
- Continuous Power
- 4.2 Watt
- Frequency Response
- 90 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Blue
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - lithium polymer
- 9.43 cm x 4.22 cm x 7.57 cm
- 190 g
- Product Type
- Auracast multi-speaker
- Protection
- Enclosure Colour
- Blue
- Design Features
- Built-in hang loop
Speaker System
- Speaker Type
- Active
- Continuous Power
- 4.2 Watt
- Continuous Power Details
- RMS
- 90 - 20000 Hz
- Signal-To-Noise Ratio
- 85 dB
- Amplifier
- Integrated
- Bluetooth 5.3
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- App-Controlled
Speaker System Details
- Driver Details
- Speaker: full-range driver - 1.75"
- Connector Type
- DC power input (USB Type-C)
- Included Accessories
- USB-C cable
- IP67
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - lithium polymer
- Capacity (Ah)
- 850 mAh
- Capacity (Wh)
- 3.23 Wh
- Voltage Provided
- 3.8 V
- Run Time (Up To)
- 7 hour(s)
- Recharge Time
- 3 hour(s)
- 9.43 cm
- 4.22 cm
- 7.57 cm
- 190 g
- Shipping Weight
- 320 g
- 45 °C
JBL Go 4 - Blue
