JBL Go 4 - Blue
JBL Go 4 - Blue
Quicklinx: HWWZWS00 Mfr#: JBLGO4BLU
Colours:
33 In Stock
£29.16 ex VAT
£34.99 inc VAT
JBL Go is a full-featured, great-sounding, great-value portable speaker.
  • Ultra-portable JBL Pro Sound with punchier bass
    Don't let its little size fool you. The JBL Go 4 packs a serious musical punch, delivering big JBL Pro Sound with punchy bass. Your friends won't believe how much great JBL Pro Sound comes out of such a small speaker.
  • Up to 7 hours of playtime plus 2 hours with Playtime Boost
    Don't sweat the small stuff like charging your battery. JBL Go 4 gives you up to 7 hours of playtime on a single charge. Simply tap Playtime Boost to prolong the playtime, adding up to 2 hours to your battery life. It tunes and optimizes the performance for louder and crisper sounds.
  • Waterproof and dustproof
    The JBL Go 4's IP67 waterproof and dustproof rating ensures this portable speaker can handle almost any environment, from a poolside party to a seaside picnic.
  • Multi-speaker connection by Auracast
    Want even bigger JBL Pro Sound? Pair two Go 4s for stereo sound, or wirelessly connect multiple JBL Auracast-enabled speakers using Auracast for even bigger sound.
  • Made in part with recycled materials
    The JBL Go 4 incorporates post-consumer recycled plastic and fabric for the speaker grille.
JBL Go 4 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Dustproof, waterproof
Speaker Type
Active
Continuous Power
4.2 Watt
Frequency Response
90 - 20000 Hz
Amplifier
Integrated
Bluetooth
Blue
Power Options
USB charging
Speaker battery rechargeable - lithium polymer
9.43 cm x 4.22 cm x 7.57 cm
190 g
Auracast multi-speaker
Protection
Enclosure Colour
Blue
Design Features
Built-in hang loop
Speaker System
Speaker Type
Active
Continuous Power
4.2 Watt
Continuous Power Details
RMS
Frequency Response
90 - 20000 Hz
Signal-To-Noise Ratio
85 dB
Amplifier
Integrated
Bluetooth 5.3
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
App-Controlled
Speaker System Details
Driver Details
Speaker: full-range driver - 1.75"
Connector Type
DC power input (USB Type-C)
USB-C cable
IP67
Power Source
Options
USB charging
Rechargeable - lithium polymer
Capacity (Ah)
850 mAh
Capacity (Wh)
3.23 Wh
Voltage Provided
3.8 V
Run Time (Up To)
7 hour(s)
Recharge Time
3 hour(s)
9.43 cm
4.22 cm
7.57 cm
190 g
Shipping Weight
320 g
45 °C
Brand: JBL
