Enjoy surprisingly powerful, room-filling stereo sound with the JBL Flip Essential ultra-compact portable Bluetooth speaker. Powered by a rechargeable battery, it delivers hours of non-stop, high-quality playtime.
Wireless Bluetooth streaming
Wirelessly stream high-quality, room-filling sound from your smartphone or tablet. -
Waterproof design
Take the Flip Essential to the beach or the pool without worrying about spills or even submersion in water. -
Durable fabric material
The durable fabric material and rugged rubber housing allows your speaker to outlast all of your adventures. -
Bass radiator
Dual external passive radiators deliver powerful, ear catching JBL sound that resonates loud and clear, allowing you to hear the bass, feel the bass, and see the bass.
- JBL Flip Essential - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Enclosure Design
- Passive radiator
- Speaker Type
- Active
- Continuous Power
- 16 Watt
- Frequency Response
- 80 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - stereo x 2 - 8 Watt - 80 - 20000 Hz - active
- Gun metal
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - lithium polymer
- 16.9 cm x 6.4 cm x 6.4 cm
- 470 g
- Product Type
- Protection
- Waterproof
- Enclosure Colour
- Gun metal
- Enclosure Design
- Passive radiator
- Enclosure Material
- Rubber, textile
Speaker System
- Speaker Type
- Active
- Continuous Power
- 16 Watt
- 80 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Amplifier
- Integrated
- Bluetooth 4.1
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Controls
- Power on/off, volume, play/pause
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 8 Watt - 80 - 20000 Hz CFR - active
- Driver Details
- Speaker: 2 x full-range driver , Speaker: 2 x Passive Radiator
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- USB charging cable
- IPX7
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - lithium polymer
- Capacity (Ah)
- 3000 mAh
- Run Time (Up To)
- 10 hour(s)
- Recharge Time
- 3.5 hour(s)
- 16.9 cm
- 6.4 cm
- 6.4 cm
- 470 g
