JBL Flip 6 - Blue
JBL Flip 6 - Blue
Quicklinx: HWVHWS00 Mfr#: JBLFLIP6BLU
Speaker Type: Speaker
Connection: Wireless
Colours:
Hurry, only 1 left in stock!
£107.50 ex VAT
£129.00 inc VAT
The JBL Flip 6 features innovation inside and out but remains true to its legendary predecessors. The new logo design, premium materials, and refreshed color range, house a brand new audio set up. JBL Flip 6 delivers even better JBL Pro Sound in the most stylish package yet.
As the perfect companion for powerful sound on the go, the JBL Flip 6 boasts connectivity and durability. Join forces with your friends to make your sound bigger and better than ever with PartyBoost and feel at ease indoors and out with IP67 water and dustproof rating. With 12 hours of playtime, your JBL Flip 6 will last just as long as you do.
A new audio configuration features dual passive radiators, powerful racetrack-shaped woofer and separate tweeter. The JBL Flip 6 delivers music with every stunning detail from bass, to mids, to highs.
  • Bluetooth technology
    The JBL Flip portable speaker streams stereo music wirelessly from any Bluetooth-equipped device. This arrangement makes JBL sound available for a wide range of portable devices, including tablets.
  • Built-in bass port
    Some portable speakers struggle to produce bass, but not JBL portable speakers. The JBL Flip has a built-in bass port and generates bass that's superior to comparable portable products.
  • Digital signal processing
    JBL speakers - even small ones - aren't misers when it comes to delivering great sound. The JBL Flip employs digital signal processing to generate room-filling audio with great bass from a compact speaker.
  • Built-in microphone and call-answer button
    Not all of the sounds from the JBL Flip come from your music. There's a microphone and a call-answer button so you can answer phone calls from the speaker.
  • 5-hour, lithium-ion rechargeable battery
    The JBL Flip stereo speaker has a built-in lithium-ion rechargeable battery that provides up to five hours of playback time. You can easily recharge the battery using the adapter, which saves you battery hassles and money.
  • Versatile, portable design
    The JBL Flip stereo speaker plays from either a vertical or horizontal position, so you can place it in a variety of locations. And it fits easily into a backpack, so you can take it from one place to the next.
  • LED indicator
    A clearly visible LED lets you know when the built-in battery needs to be recharged, as well as when the JBL Flip is in Bluetooth listening or pairing mode.
JBL Flip 6 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Waterproof, dustproof
Enclosure Design
Passive radiator
Speaker Type
2-way - active
Continuous Power
30 Watt
Frequency Response
63 - 20000 Hz
Amplifier
Integrated
Bluetooth 5.1
Blue
Power Options
USB charging
Speaker battery rechargeable - lithium polymer
17.8 cm x 7.2 cm x 6.8 cm
550 g
1-year warranty
PartyBoost
Protection
Enclosure Colour
Blue
Enclosure Design
Passive radiator
Speaker System
Speaker Type
2-way - active
Continuous Power
30 Watt
Continuous Power Details
RMS
Frequency Response
63 - 20000 Hz
Signal-To-Noise Ratio
80 dB
Amplifier
Integrated
Bluetooth 5.1
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
App-Controlled
Speaker System Details
Driver Details
Speaker: woofer driver - 1.75" x 3" - racetrack , Speaker: tweeter driver - 0.6" , Speaker: 2 x Passive Radiator
Connector Type
DC power input (USB Type-C)
USB-C cable (1.2m)
IP67
Power Source
Options
USB charging
Rechargeable - lithium polymer
Capacity (Ah)
4800 mAh
Capacity (Wh)
17.28 Wh
Voltage Provided
3.6 V
Run Time (Up To)
12 hour(s)
Recharge Time
2.5 hour(s)
17.8 cm
7.2 cm
6.8 cm
550 g
Shipping Width
21.6 cm
Shipping Depth
9.9 cm
Shipping Height
10.6 cm
Shipping Weight
920 g
Limited warranty - 1 year
45 °C
Brand: JBL
