Looking for impressive sound that you can take anywhere? Say no more. The Flip 5 takes sound quality to great heights with an acoustic design. The racetrack-shaped driver with increased cone area and excursion amplifies JBL’s classic signature sound, elevating the overall output of the music delivering crisp highs and deep bass.
Like its predecessor, the JBL Flip 5 sports a waterproof, compact design, which means there’s no stopping where this speaker can travel. Small enough to pack in a suitcase, bring it to mountaintop soirees and your beach excursions, no matter the weather. Boasting 12 hours of playtime and recharging capabilities via a USB-C charging port means this speaker will be up and running with stronger battery support than ever before. A built-in speakerphone, alongside its stellar and stable Bluetooth connection, lets users make and receive crystal clear calls with the touch of a button.
Sounds better than ever
Feel your music. Flip 5's racetrack-shaped driver delivers high output. Enjoy booming bass in a compact package. -
Bring the party anywhere
Don't sweat the small stuff like charging your battery. Flip 5 gives you more than 12 hours of playtime. Keep the music going longer and louder with JBL's signature sound. -
Make a splash with IPX7 waterproof design
Bring your speakers anywhere. Pool party? Perfect. Sudden cloudburst? Covered. Bash on the beach? Flip 5 is IPX7 waterproof up to three-feet deep for fearless outdoor entertainment. -
Crank up the fun with PartyBoost
PartyBoost allows you to pair two JBL PartyBoost-compatible speakers together for stereo sound or link multiple JBL PartyBoost-compatible speakers to pump up your party. -
Tough as it sounds
Slip this little gem onto your wrist and get grooving. Its durable fabric material and rugged rubber housing keep the Flip 5 safe while you let loose in the great outdoors.
- JBL Flip 5 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - active
- Fiesta red
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- Product Type
- Hands-Free Function
- Protection
- Waterproof
- Enclosure Colour
- Fiesta red
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
Speaker System Details
- Speaker Details
- Speaker - active
- Connector Type
- DC power input (USB Type-C)
- IPX7
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 4800 mAh
- Run Time (Up To)
- 12 hour(s)
