JBL Endurance PEAK 3 True Wireless Sport Earbuds Black
Quicklinx: HWX0WS00 Mfr#: JBLENDURPEAK3BLK
Type: Earbuds
Connectivity: Wireless
Colour: Black
38 In Stock
£74.99 ex VAT
£89.98 inc VAT
Your lifestyle is active - you need wireless earbuds that can keep up. The Endurance Peak 3 is the perfect training partner, pumping your motivational playlists to you with long hours of playback and rich JBL Pure Bass Sound you can feel in your muscles. The durable IP68 dust and water proof design can handle the dustiest mountain trail and the sweatiest gym session, while a bendable TwistLock ear hook enhancer ensures a secure, comfortable fit that stays in no matter how you move your body. And with the ability to make crystal clear calls from anywhere and stay aware of your surroundings, you'll stay connected to the world no matter where your workout takes you.
  • JBL pure bass sound
    Get the most out of your favorite workout playlist with rich bass from a 10 mm dynamic driver that delivers bold sound when you need it most.
  • IP68 dust and water proof
    An IP68 rating means the JBL Endurance Peak 3 earbuds are ready for your most active adventures, rain or shine. And they'll endure for 30 minutes at depths up to 1.5 meters of salt or fresh water. So, you can surf with your earbuds, or rinse them after a workout, all without missing a beat.
  • Ambient aware and TalkThru
    whether you're out for a run or in the zone at the gym, TalkThru makes it easy to make and hear calls anywhere. And with Ambient Aware, you can stay alert to your surroundings without removing your headphones.
  • 4-microphone crisp, clear calls
    Even on a windy bike trail, your voice will be heard thanks to dual beamforming mics in each ear help to ensure clear communication. And with VoiceAware, you can choose how much of your own voice to hear by controlling the amount of mic input routed back into your earbuds.
  • Powerhook design for an ergonomic fit
    The JBL Endurance Peak 3 adjusts to fit comfortably with a bendable TwistLock ear hook enhancer that ensures your headphones won't fall out - even during your most active moments. And when you take them off, the earbuds will automatically switch off even if you don't put them back in the charging case.
JBL Endurance Peak 3 - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Style
Sports
Headphones Form Factor
Ear-bud - behind-the-neck mount
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
Pure Bass
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
16 Ohm
Signal-To-Noise Ratio
93 dB
True wireless earphones - Bluetooth - wireless
Style
Sports
Dimensions & Weight Details
Charging case: 76 g
Recommended Use
Protection
IP68
Audio Output
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.2
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Sound Effects
Pure Bass
Frequency Response
20 - 20000 Hz
93 dB
Impedance
16 Ohm
Max Sound Pressure
102 dB
Diaphragm
10 mm
PowerHook
Microphone
Built-in
3 pairs of ear tips (small, medium, large), charging case, 1 pair of enhancers, USB-C charging cable
Headphone battery rechargeable - lithium polymer
70 mAh
Run Time (Up To)
10 hours
Run Time Details
Continuous playback (with included charging case): up to 40 hours , Continuous talk: up to 5.5 hours
Recharge Time
2 hours
Type: Earbuds
Colour: Black
Brand: JBL
