JBL Clip 5 - Black
JBL Clip 5 - Black
Quicklinx: HWVDWS00 Mfr#: JBLCLIP5BLK
Colours:
46 In Stock
£41.66 ex VAT
£49.99 inc VAT
The JBL Clip is the ultra-light, ultra-rugged, and ultra-powerful portable speaker. This powerful little box gives you the battery power so you can take the music with you where ever you go, Plus you can plug it in easily to any portable device using its 3.5 mm integrated audio cable, but you can play it wirelessly too using its Bluetooth 4.0 functionality, streaming your music with no strings or cables attached or talking with your friends using its hands-free speakerphone function. But where the JBL Clip truly earns its name is its built-in carabiner, letting you hook it easily to whatever clothes you're wearing or backpack you're shouldering .On-the-go listeners, listen up: here's a portable speaker that keeps pace with whatever pace you set.
  • Ultra-portable JBL Pro Sound
    Don't let its little size fool you. The JBL Clip 5 packs a serious musical punch, delivering big JBL Pro Sound with punchy bass. Your friends won't believe how much great JBL Pro Sound comes out of such a small speaker.
  • Redesigned carabiner
    The completely redesigned, fully integrated carabiner has a much wider opening that makes it even more portable. You can attach the Clip 5 to everything from your backpack to your belt loop, and take your music with you all day, everywhere.
  • Up to 12 hours of playtime plus 3 hours with Playtime Boost
    Don't sweat the small stuff - like charging your battery. JBL Clip 5 gives you up to 12 hours of playtime on a single charge. Simply tap Playtime Boost to prolong the playtime, adding up to 3 hours to your battery life. It tunes and optimizes the performance for louder and crisper sounds.
  • Waterproof and dustproof
    The IP67 waterproof and dustproof rating of the JBL Clip 5 ensures that this portable speaker can withstand almost any environment, from a poolside party to a seaside picnic.
  • Multi-speaker connection by Auracast
    Want even bigger JBL Pro Sound? Pair two Clip 5s for stereo sound, or wirelessly connect multiple Auracast-enabled speakers using Auracast for even bigger sound.
  • Made in part with recycled materials
    The JBL Clip 5 incorporates post-consumer recycled plastic and fabric for the speaker grille.
JBL Clip 5 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Dustproof, waterproof
Speaker Type
Active
Continuous Power
7 Watt
Frequency Response
95 - 20000 Hz
Amplifier
Integrated
Bluetooth
Power Options
USB powered
Speaker battery rechargeable - lithium polymer
8.63 cm x 4.6 cm x 13.45 cm
285 g
Auracast multi-speaker
Protection
Enclosure Colour
Enclosure Material
Recycled fabric and plastic
Design Features
Built-in carabiner clip
Speaker System
Speaker Type
Active
Continuous Power
7 Watt
Continuous Power Details
RMS
Frequency Response
95 - 20000 Hz
Signal-To-Noise Ratio
85 dB
Amplifier
Integrated
Bluetooth 5.3
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Controls
Power on/off, volume, Bluetooth source, playback controls
App-Controlled
Speaker System Details
Driver Details
Speaker: full-range driver - 1.75"
Connector Type
DC power input (USB Type-C)
USB-C to USB-A cable
IP67, GFSK, 8DPSK, Pi/4 DQPSK
Power Source
Options
USB powered
Rechargeable - lithium polymer
Capacity (Ah)
1400 mAh
Capacity (Wh)
5.32 Wh
Voltage Provided
3.8 V
Run Time (Up To)
12 hour(s)
Recharge Time
3 hour(s)
8.63 cm
4.6 cm
13.45 cm
285 g
Shipping Width
10.05 cm
Shipping Depth
5.9 cm
Shipping Height
14.8 cm
Shipping Weight
390 g
45 °C
Brand: JBL
