The JBL Clip 2 is a light, rugged and powerful portable speaker. Completely waterproof, the JBL Clip 2 provides many hours of playtime, allowing you to take your music wherever you go, be it land or water. Stream music wirelessly via Bluetooth, or plug it into any smartphone or tablet. You can also wirelessly connect two Clip 2 speakers together to enjoy amplified sound. Use the speakerphone to make clear, noise and echo free phone calls. The JBL Clip 2 is covered with durable waterproof fabric, and earns its name with its carabiner, clipping to your clothes or backpack to take on any adventure.
Wireless Bluetooth streaming
Wirelessly stream high-quality sound from your smartphone or tablet. -
Rechargeable battery
Built-in rechargeable Li-ion battery supports many hours of playtime. -
Speakerphone
Take crystal clear calls from your speaker with a touch of a button - thanks to the noise and echo free speakerphone. -
Built-in carabiner
Hook the Clip 2 onto anything you see fit and take it on all your adventures. -
IPX7 waterproof
No more worrying about rain or spills, you can even submerge the Clip 2 in water. -
Wireless daisy chain
You can wirelessly connect two Clip 2 speakers together to enjoy amplified sound.
- JBL Clip 2 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Speaker Type
- Active
- Continuous Power
- 3 Watt
- Frequency Response
- 120 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Grey
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 9.4 cm x 4.2 cm x 14.1 cm
- 184 g
- Product Type
- Hands-Free Function
- Microphone
- Protection
- Waterproof
- Enclosure Colour
- Grey
- Enclosure Material
- Fabric, rubber
- Design Features
- Built-in carabiner clip
Speaker System
- Speaker Type
- Active
- Continuous Power
- 3 Watt
- 120 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Amplifier
- Integrated
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Controls
- Power on/off, call answer
Speaker System Details
- Driver Details
- Speaker: full-range driver
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Micro-USB cable
- IPX7
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 730 mAh
- Run Time (Up To)
- 8 hour(s)
- Recharge Time
- 2.5 hour(s)
- 9.4 cm
- 4.2 cm
- 14.1 cm
- 184 g
