Take the party with you no matter what the weather. The JBL Charge 5 speaker delivers bold JBL Original Pro Sound, with its optimized long excursion driver, separate tweeter and dual pumping JBL bass radiators. Up to 20 hours of playtime and a handy powerbank to keep your devices charged to keep the party going all night. Rain? Spilled drinks? Beach sand? The IP67 waterproof and dustproof Charge 5 survives whatever comes its way. Thanks to PartyBoost, you can connect multiple JBL PartyBoost-enabled speakers for a sound big enough for any crowd. With all-new colors inspired by the latest street fashion trends, it looks as great as it sounds.
Bold JBL Original Pro Sound
Take the amazing power of JBL Pro Sound with you. The JBL Charge 5 has an optimized long excursion driver, a separate tweeter, and dual JBL bass radiators, all delivering impressively rich and clear audio. Get that big room sound, even when outdoors. -
The fun doesn't have to stop. Packed with an incredible 20 hours of battery life, JBL Charge 5 lets you party all day and into the night. -
To the pool. To the park. JBL Charge 5 is IP67 waterproof and dustproof, so you can bring your speaker anywhere. -
Wireless Bluetooth Streaming
Wirelessly connect up to 2 smartphones or tablets to the speaker and take turns enjoying JBL Pro sound. -
Crank up the fun with Party Boost
PartyBoost allows you to pair two JBL PartyBoost-compatible speakers together for stereo sound or link multiple JBL PartyBoost- compatible speakers to truly pump up your party. -
Power up with the built-in powerbank
Don't put the party on pause. A built-in powerbank lets you charge your devices without taking a break from the tunes.
 - JBL Charge 5 - speaker - for portable use - wireless
- Product Type
 - Speaker - for portable use
- Protection
 - Dustproof, waterproof
- Enclosure Design
 - Passive radiator
- Speaker Type
 - Active
- Continuous Power
 - 40 Watt
- Frequency Response
 - 65 - 20000 Hz
- Amplifier
 - Integrated
 - Bluetooth
 - Black
- Power Options
 - USB charging (powerbank function)
- Battery
 - Speaker battery rechargeable - lithium polymer
 - 22.3 cm x 9.4 cm x 9.65 cm
 - 960 g
- Product Type
 - PartyBoost
- Protection
- Enclosure Colour
 - Black
- Enclosure Design
 - Passive radiator
- Design Features
 - Rugged
Speaker System
- Speaker Type
 - Active
- Continuous Power
 - 40 Watt
 - 65 - 20000 Hz
- Signal-To-Noise Ratio
 - 80 dB
- Amplifier
 - Integrated
 - Bluetooth 5.1
- Bluetooth Profiles
 - Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Speaker System Details
- Driver Details
 - Speaker: woofer driver - racetrack , Speaker: tweeter driver , Speaker: 2 x Passive Radiator
- Connector Type
 - USB (24 pin USB-C)
- Included Accessories
 - USB-C cable
 - IP67
- Power Source
 - Battery
- Options
 - Rechargeable - lithium polymer
- Capacity (Ah)
 - 7500 mAh
- Capacity (Wh)
 - 27 Wh
- Voltage Provided
 - 3.6 V
- Run Time (Up To)
 - 20 hours
- Recharge Time
 - 4 hours
 - 22.3 cm
 - 9.4 cm
 - 9.65 cm
 - 960 g
