JBL Charge 5 - Portable Waterproof Speaker with Powerbank
Quicklinx: G9JTWS00 Mfr#: JBLCHARGE5BLK
Speaker Type: Speaker
Connection: Wireless
Colours:
£99.99 ex VAT
£119.98 inc VAT
Take the party with you no matter what the weather. The JBL Charge 5 speaker delivers bold JBL Original Pro Sound, with its optimized long excursion driver, separate tweeter and dual pumping JBL bass radiators. Up to 20 hours of playtime and a handy powerbank to keep your devices charged to keep the party going all night. Rain? Spilled drinks? Beach sand? The IP67 waterproof and dustproof Charge 5 survives whatever comes its way. Thanks to PartyBoost, you can connect multiple JBL PartyBoost-enabled speakers for a sound big enough for any crowd. With all-new colors inspired by the latest street fashion trends, it looks as great as it sounds.
  • Bold JBL Original Pro Sound
    Take the amazing power of JBL Pro Sound with you. The JBL Charge 5 has an optimized long excursion driver, a separate tweeter, and dual JBL bass radiators, all delivering impressively rich and clear audio. Get that big room sound, even when outdoors.
  • 20 hours of playtime
    The fun doesn't have to stop. Packed with an incredible 20 hours of battery life, JBL Charge 5 lets you party all day and into the night.
  • IP67 waterproof and dustproof
    To the pool. To the park. JBL Charge 5 is IP67 waterproof and dustproof, so you can bring your speaker anywhere.
  • Wireless Bluetooth Streaming
    Wirelessly connect up to 2 smartphones or tablets to the speaker and take turns enjoying JBL Pro sound.
  • Crank up the fun with Party Boost
    PartyBoost allows you to pair two JBL PartyBoost-compatible speakers together for stereo sound or link multiple JBL PartyBoost- compatible speakers to truly pump up your party.
  • Power up with the built-in powerbank
    Don't put the party on pause. A built-in powerbank lets you charge your devices without taking a break from the tunes.
JBL Charge 5 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Waterproof, dustproof
Enclosure Design
Passive radiator
Speaker Type
Active
Continuous Power
40 watt
Frequency Response
65 - 20000 Hz
Amplifier
Integrated
Bluetooth 5.1
Power Options
USB charging (powerbank function)
Speaker battery rechargeable - lithium polymer
22.3 cm x 9.4 cm x 9.65 cm
960 g
PartyBoost
Protection
Enclosure Colour
Enclosure Design
Passive radiator
Design Features
Rugged
Speaker System
Speaker Type
Active
Continuous Power
40 watt
Frequency Response
65 - 20000 Hz
Signal-To-Noise Ratio
80 dB
Amplifier
Integrated
Bluetooth 5.1
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Speaker System Details
Driver Details
Speaker: woofer driver - racetrack , Speaker: tweeter driver , Speaker: 2 x Passive Radiator
Connector Type
USB (24 pin USB-C)
USB-C cable
IP67
Power Source
Options
Rechargeable - lithium polymer
Capacity (Ah)
7500 mAh
Capacity (Wh)
27 Wh
Voltage Provided
3.6 V
Run Time (Up To)
20 hours
Recharge Time
4 hours
22.3 cm
9.4 cm
9.65 cm
960 g
Brand: JBL
