JBL Charge 4 Portable Bluetooth Speaker - Blue
Quicklinx: FDVZWS00 Mfr#: JBLCHARGE4BLU
Colours:
The JBL Charge 4 is a musical force to be reckoned with, boasting hours of playtime and the ability to charge any smart device through the speaker's charging port. No more worrying about cutting that playlist short, the music will be going strong as long as the party.
  • Wireless Bluetooth streaming
    Wirelessly connect to up to 2 smartphones or tablets to the speaker and take turns enjoying powerful sound.
  • Waterproof design
    Take the speaker to the beach or the pool without worrying about spills or even submersion in water.
  • Durable fabric and rugged materials
    The durable fabric material and rugged rubber housing allows for speakers to outlast any adventure.
JBL Charge 4 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Waterproof
Speaker Type
Active
Nominal Output Power (Total)
30 Watt
Peak Power
30 Watt
Frequency Response
60 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - stereo x 2 - active
Ocean blue
Image Colour Disclaimer
The displayed product image may be a different colour
Power Options
USB charging (powerbank function)
Speaker battery rechargeable
Protection
Waterproof
Enclosure Colour
Ocean blue
Speaker System
Speaker Type
Active
Audio System Continuous Power (Total)
30 Watt
Peak Power
30 Watt
Frequency Response
60 - 20000 Hz
Signal-To-Noise Ratio
80 dB
Amplifier
Integrated
Bluetooth 4.2
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Compatible Software
JBL Connect+
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x full-range driver , Speaker: 2 x Passive Radiator
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , USB (power only) (4 pin USB Type A (power only))
IPX7
Max Depth of Water Resistance
1 m
Power Source
Options
Rechargeable
Capacity (Ah)
7500 mAh
Run Time (Up To)
20 hour(s)
