JBL Bar Studio 2.0-Channel Soundbar with Bluetooth
Quicklinx: FB8MWS00 Mfr#: JBLBARSBLKUK
JBL Bar Studio compact soundbar provides stellar sound for your favorite TV series, movies and music. It's slim, incomparably designed and extremely easy to use. JBL surround sound and double bass ports turn your TV sound into real cinema sound. The JBL Bar Studio offers Bluetooth connectivity, so that you can stream your favorite music to the speaker, wirelessly. It is easy to set up with just one single HDMI cable to connect between your TV and the soundbar. You can control the JBL Bar Studio with your existing TV remote control.
  • All-in-one soundbar with built-in dual bass port design
    Enjoy significantly better sound with more bass from your TV series, movies, and music through dual bass port design.
  • JBL surround sound
    Bring movies to life with JBL surround sound, without the hassle of any additional wires or speakers.
  • Wireless music streaming with Bluetooth
    Stream all your music wirelessly from any mobile device.
  • HDMI (ARC) connection
    All you need to do is connect a single HDMI cable between the soundbar and your TV.
  • Works with your TV remote control
    This JBL soundbar is designed to work with many of today's top TV remote controls, so you can use your existing TV remote control for both TV and soundbar.
JBL Bar Studio - sound bar - wireless
Sound bar - 2.0-channel
Enclosure Design
Bass reflex
Speaker Type
Active
Continuous Power
30 Watt
Frequency Response
60 - 20000 Hz
Bluetooth
Sound Effects
JBL Surround Sound
61.4 cm x 8.6 cm x 5.8 cm
1.4 kg
1-year warranty
Dual Bass Port
Enclosure Colour
Enclosure Design
Bass reflex
Speaker System
Speaker Type
Active
Continuous Power
30 Watt
Frequency Response
60 - 20000 Hz
Max Output Level (Max SPL)
90 dB
Sound Effects
JBL Surround Sound
Bluetooth 4.2
Recommended Placing
Wall-mountable
Speaker System Details
Driver Details
Sound bar: 2 x woofer driver - 2" , Sound bar: 2 x tweeter driver - 1.5"
Connector Type
HDMI output (19 pin HDMI Type A) , Audio line-in , Digital audio input (optical) (TOS Link) , USB
Audio cable, remote control, wall mounting kit, batteries, audio (optical) cable
HDCP 1.4
Power Source
AC power adapter
61.4 cm
8.6 cm
5.8 cm
1.4 kg
- 1 year
