Make movie night soar and let your music move you to new heights with 720 W of total output power and thrilling bass from the 10" subwoofer. The JBL Bar 800 with Dolby Atmos includes two up-firing drivers and detachable battery-powered surround speakers to create an immersive 3D cinema experience without having to draw extra cables. You'll never miss a word with the PureVoice technology, which makes sure dialogs are clear even when other sounds are at their loudest. And when you're ready to cut loose, stream your favorite music from AirPlay, Alexa MRM, or Chromecast built-in. Your get-togethers will never be the same.
True Dolby Atmos surround sound
Immerse yourself in theater-quality 3D sound. With two up-firing drivers, the JBL Bar 800 delivers true Dolby Atmos 3D surround sound. -
Real surround sound with detachable surround speakers
Enjoy real surround sound without the hassle of extra wires and power connections. Just place the two detachable battery-powered surround speakers behind you and get swept away in amazing audio. -
720 W output power
With 720 watts of total system power the JBL Bar 800 transforms your movies, music and games into immersive sound experiences and pulls you into the middle of the action. -
10" wireless subwoofer
Thrilling, precise bass from a mighty 10" wireless subwoofer brings the excitement to your action movies and the emotion to your music. -
PureVoice Dialog Enhancement technology
PureVoice technology uses the unique algorithm to optimize voice clarity to ensure you never miss a word of dialog, even when the surround effects are at their peak. -
HDMI eARC with 4K Dolby Vision passthrough
Enjoy uncompressed Dolby Atmos surround sound through a single HDMI cable thanks to the HDMI eARC connection. The HDMI input connection also offers 4K video quality from a compatible video player or gaming console. -
Easy sound calibration
Every room is different. The calibration feature ensures that the JBL Bar 800 delivers the best 3D surround effects for any interior and room layout. -
Works with voice assistant-enabled speakers
Simply link the JBL Bar 800 with your voice assistant-enabled device and you can instantly ask Alexa, Google Assistant, or Siri to stream all your favorite music to the soundbar.
 - JBL Bar 800 - sound bar system - for home theatre - wireless
- Product Type
 - Sound bar system - for home theatre - 5.1.2-channel
- Media Content Source
 - Chromecast
- Localisation
 - United Kingdom
- System Components
 - 2 speakers, subwoofer, sound bar
- Speaker Type
 - Active
- Audio System Peak Power (Total)
 - 720 Watt
- Amplifier
 - Integrated
 - Bluetooth, Wi-Fi 6
- Intelligent Assistant
 - Siri, Google Assistant, Alexa ready - indirect
- AirPlay
- Streaming Services
 - Chromecast
- Speaker System Details
 - 1 x sound bar 340 Watt , 1 x subwoofer 300 Watt , 2 x surround channel speaker 40 Watt
 - Black
- Built-in Decoders
 - Dolby Atmos
- Sound Effects
 - 3D surround sound
- Power
 - AC 100-240 V (50/60 Hz)
- Battery
 - Speaker battery rechargeable - lithium
- Product Type
 - Auto sound calibration, PureVoice technology
 - Chromecast
- Enclosure Colour
 - Black
- Design Features
 - Detachable wireless battery-powered surround channel speakers
- Localisation
 - United Kingdom
Speaker System
- System Components
- Speaker Type
 - Active
 - 720 Watt
- Frequency Response (-6dB)
 - 35 - 20000 Hz
- Multiroom
- Multiroom Technology
 - Alexa Multi-Room Music (MRM)
- Amplifier
 - Integrated
- Sound Effects
 - 3D surround sound
- Audio Return Channel (ARC) Capability
 - Bluetooth 5.0, IEEE 802.11a/b/g/n/ac/ax
- Bluetooth Profiles
 - Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- AirPlay
- Video Pass-Through
 - 2160 (4K)
- Internet Streaming Services
 - Chromecast
- Recommended Placing
 - Wall-mountable / table-top
- Built-in Decoders
 - Dolby Atmos
- App-Controlled
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Voice Control
 - Indirect
- Speakers Included
 - 1 x sound bar - 340 Watt - wall-mountable / table-top , 1 x subwoofer - 300 Watt - wireless , 2 x surround channel speaker - 40 Watt - wireless
- Driver Details
 - Sound bar: 3 x mid-range driver - racetrack , Sound bar: 3 x tweeter driver - 0.75" , Sound bar: 2 x full-range driver - 2.75" - up-firing driver
- Driver Details (2nd speaker)
 - Subwoofer: subwoofer driver - 10"
- Driver Details (3rd speaker)
 - Surround channel speakers: mid-range driver - racetrack
- Connector Type
 - HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Digital audio input (optical) (TOS Link)
- Included Accessories
 - Remote control, wall mounting kit, HDMI cable, 2 batteries, wall mount template, 4 x side caps, power cables
 - HDCP 2.3
- Power Source
 - Integrated power supply
- Voltage Required
 - Rechargeable - lithium
- Capacity (Ah)
 - 3283 mAh
- Dimensions (WxDxH) / Weight Details
 - Sound bar: 88.4 cm x 12 cm x 5.6 cm / 3.4 kg , Subwoofer: 30.5 cm x 30.5 cm x 44.04 cm / 10 kg , Surround channel speaker: 14.5 cm x 12 cm x 5.6 cm / 650 g
- Shipping Width
 - 100 cm
- Shipping Depth
 - 47.5 cm
- Shipping Height
 - 37.5 cm
- Shipping Weight
 - 18.9 kg
 - 0 °C
 - 45 °C
