JBL 5.1-Channel 4K Ultra HD Soundbar with True Wireless Surround
Quicklinx: DBFDWS00 Mfr#: JBLBAR51BLKEP
The JBL Bar 5.1 transforms from a soundbar into a true wireless 5.1 home theater system for an epic movie and music-listening experience. The soundbar features two detachable battery-powered wireless surround speakers with long hours of playtime, total system power, a wireless subwoofer, HDMI inputs to connect 4K devices and Bluetooth. With Dolby Digital, Dolby Pro Logic II and DTS, your movies, music and video games will never sound more incredible. The soundbar features JBL SoundShift, which allows you to instantly switch between the sound from your TV and the Bluetooth sound from your mobile phone or tablet. The soundbar is programmed to respond to your TV remote, so you can control everything with your existing TV remote control. The JBL Bar 5.1 redefines the soundbar experience.
  • JBL 5.1 surround sound with high power
    Ensures a high-quality audio performance for your movies and music.
  • Detachable, battery-powered wireless surround speakers
    Enjoy true wireless surround sound in cinematic 5.1 with long hours of playing time.
  • Thrilling bass from a wireless subwoofer
    Enjoy rich and thrilling bass with the convenience of flexible placement without the hassle of wires.
JBL Bar 5.1 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 5.1-channel
System Components
2 speakers, subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
510 Watt
Frequency Response
35 - 20000 Hz
Bluetooth
Speaker System Details
1 x sound bar , 1 x subwoofer , 2 x surround channel speaker
Built-in Decoders
Dolby Pro Logic II, Dolby Digital, DTS decoder
1-year warranty
Design Features
Detachable wireless battery-powered rear channel speakers
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
510 Watt
Frequency Response
35 - 20000 Hz
Max Output Level (Max SPL)
104 dB
Audio Return Channel (ARC) Capability
Bluetooth 4.2
Video Pass-Through
2160 (4K)
Built-in Decoders
Speakers Included
1 x sound bar - wall-mountable , 1 x subwoofer - wireless , 2 x surround channel speaker - wireless
Driver Details
Sound bar: 6 x mid-range driver - 2.25" , Sound bar: 3 x tweeter driver - 1.25"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 10"
Connector Type
3 x HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , Digital audio input (optical) (TOS Link) , USB
Audio cable, digital audio cable (optical), remote control, wall mounting kit, HDMI cable, batteries, calibration microphone
Dimensions (WxDxH) / Weight Details
Sound bar: 114.8 cm x 9.3 cm x 5.8 cm / 3.9 kg , Subwoofer: 44 cm x 30.5 cm x 30.5 cm / 13 kg , Surround channel speaker: 16.2 cm x 9.3 cm x 5.9 cm / 600 g
Limited warranty - 1 year
