JBL 2.1-Channel Soundbar with Wireless Subwoofer
Quicklinx: DBFBWS00 Mfr#: JBLBAR21BLKEP
Enjoy JBL sound with 300W of power
The 300W of power output ensures great audio performance for your movies and music.
JBL Surround Sound makes movies come alive
Bring movies to life with JBL Surround Sound, without the hassle of any additional wires or speakers.
Rich and deep bass from a 6.5" (165mm) wireless subwoofer
Enjoy rich and deep bass as well as the convenience of flexible placement without the hassle of wires.
  • Wireless music streaming with Bluetooth: Stream all your music wirelessly from any mobile device.
  • Connect your devices with HDMI IN/ 1 HDMI out (ARC): Connect your devices and simplify your home entertainment setup.
  • Works with your TV remote control: This JBL soundbar is designed to work with many of today's top TV remote controls, so you can use your existing TV remote control for both TV and soundbar.
  • Enjoy JBL sound with 300W of power
  • JBL Surround Sound makes movies come alive
  • Rich and deep bass from a 6.5" wireless subwoofer
  • Connect your devices with HDMI in/1 HDMI out
JBL Bar 2.1 - sound bar system - wireless
Sound bar system - 2.1-channel
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
300 Watt
Frequency Response
40 - 20000 Hz
Bluetooth
Speaker System Details
1 x sound bar , 1 x subwoofer
Black-EMEA
Built-in Decoders
Dolby Digital
Sound Effects
JBL Surround Sound
Enclosure Colour
Black-EMEA
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
300 Watt
Frequency Response
40 - 20000 Hz
Max Output Level (Max SPL)
99 dB
Sound Effects
JBL Surround Sound
Bluetooth 4.2
Recommended Placing
Wall-mountable
Built-in Decoders
Dolby Digital
Speakers Included
1 x sound bar , 1 x subwoofer - wireless
Driver Details
Sound bar: 4 x mid-range driver - 2.25" , Sound bar: 2 x tweeter driver - 1.25"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 6.5"
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in , Digital audio input (optical) (TOS Link) , USB
Audio cable, remote control, wall mounting kit, batteries, audio (optical) cable
HDCP 1.4
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Sound bar: 96.5 cm x 6.8 cm x 5.8 cm / 1.9 kg , Subwoofer: 22.5 cm x 22.5 cm x 37 cm / 5.2 kg
