The world's most advanced tracker
Everyone has had a life-changing experience sometime. This is one of those times. UP3™ is simply the most advanced tracker you can buy. Its classic, durable design will stand the test of time. Multi-sensor technology adds breadth and accuracy to Smart Coach. Everything about UP3 says that the bar has been set higher. Wear one and go further.
Advanced activity
The more you do, the smarter UP3 becomes, by learning to recognize and automatically log all your activities from running to a pickup game of basketball. Smart enough to know what you're doing, UP3 gives you a detailed picture of your calorie burn. -
Advanced sleep
UP3 uses advanced sensors to track your true sleep stages - REM, Light, and Deep. Smart Coach is then able to give you suggestions to maximize your sleep and improve the quality of your days. -
Smart Coach
Because the UP3 band captures so much information, Smart Coach is even smarter. It uses everything it learns about your activity, sleep, food and resting heart rate, so it can give you deeper insight and more personalized tips to reach your goals faster. -
Heart Health
There's more to your heart health than beats per minute. The advanced bio impedance sensors are able to automatically track your resting heart rate and use that information to help you take care of the most important organ in your body. -
Wireless syncing
You're always connected via Bluetooth Smart, so you never have to worry about plugging in to upload your data. -
Auto Activity Classification
Smart enough to know what you're doing. UP3 learns, recognizes and automatically logs all your fitness activities, from running to a pickup game of basketball. -
LED indicator
Simple LED indicator lights show your mode status, at a glance. -
Food & drink logging
With UP you can easily track food, drink, calories, nutrients and more. -
Set goals
Set goals to personalize your path: from steps per day and hours slept to target weight. -
Water-resistant
UP3 can swim - and dive. It is water resistant to 10m, so it can go wherever you go.
- Jawbone UP3 activity tracker - sand twist
- Product Type
- Activity tracker
- Tracking Data
- Distance, calories burned, activity, sleep activity, heart rate, steps taken, food & drink logging
- Connectivity
- Bluetooth
- Case
- Rubber, anodised aluminium
- LED indicator(s)
- Supported Host Device OS
- iOS, Android
- Battery
- Lithium polymer - 38 mAh
- Sand twist
- 12.2 mm x 9.3 mm
- Length
- 220 mm
- 29 g
- 1-year warranty
- Product Type
- Activity tracker
- Android 4.3 (Jelly Bean) or later
- Tracking Data
- Sand twist
- Sensors
- Thermometre, heart rate, galvanic skin response sensor, 3-axis accelerometer
- LED indicator(s)
- Wireless Interface
- Bluetooth 4.0
- Technology
- Lithium polymer
- Capacity
- 38 mAh
- Standby Time
- 168 h
- Recharge Time
- 100 min
- 12.2 mm
- 9.3 mm
- Length
- 220 mm
- 29 g
- Vibrating Alert
- Body Material
- Protection
- Splashproof
- Included Accessories
- Magnetic charging cable
- Warranty
- 1-year warranty
