Jabra USB cable (1.8m) for Jabra Panacast
Quicklinx: FBVFWS00 Mfr#: 14202-09
This cable connects Jabra PanaCast to either your computer or the Jabra Hub.
  • Effortless connectivity
    The Jabra PanaCast features a USB cable for seamless connection to a wide range of devices, ensuring you're always ready to go without the hassle of complex setup procedures.
  • Versatile I/O options
    Equipped with a high-quality USB cable, this device offers flexible I/O cable type options, making it compatible with various setups and enhancing its utility across different platforms.
Jabra PanaCast - USB cable - 1.8 m
USB cable
Length
1.8 m
PanaCast 50, 50 Room System
USB cable
Length
1.8 m
Jabra PanaCast 50, 50 Room System
