The Jabra USB-C adapter enables you to connect your Jabra USB headsets to USB-C devices, providing the same functionality as though connected to a USB-A device. The adapter is flexible, which makes it easy to use with your preferred devices without flipping around.
Effortless connectivity
This Jabra USB-C adapter bridges the gap between USB-C and 9-pin USB Type-A connections, offering a seamless connection experience. With a male 24-pin USB-C on one end and a female 9-pin USB Type-A on the other, it ensures compatibility across a wide range of devices. -
Plug-and-Play convenience
Designed to meet the Plug-and-Play compliant standards, this adapter simplifies the setup process, eliminating the need for additional drivers or software. Just connect it, and you're ready to go, making it perfect for quick and easy use on-the-go.
- Jabra - USB-C adapter - 24 pin USB-C to USB Type A
- USB-C adapter
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 9 pin USB Type A - female
- Designed For
- PanaCast 20
- USB-C adapter
- Connector
- Plug and Play
- Designed For
- Jabra PanaCast 20
Jabra USB-A to USB-C Adapter
