Jabra USB-A to USB-C Adapter
Quicklinx: D74TWS00 Mfr#: 14208-14
£7.75 ex VAT
£9.30 inc VAT
The Jabra USB-C adapter enables you to connect your Jabra USB headsets to USB-C devices, providing the same functionality as though connected to a USB-A device. The adapter is flexible, which makes it easy to use with your preferred devices without flipping around.
Jabra USB-C adapter
USB-C adapter
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type A - female
USB-C adapter
Connector
24 pin USB-C - male
Plug and Play
Brand: Jabra
Price Range Ex VAT: 0 - 50
