Jabra UC Voice 550 MS Duo Wired Headset
Quicklinx: 7NL2WS00 Mfr#: 5599-823-109
The Jabra UC Voice 550 is a corded headset designed specifically for unified communication deployments. The headset is made for desk-centric professionals who occasionally work from different locations and need to take the headset with them. It appeals to users favoring the classic leatherette design.
  • Crystal-clear sound
    The Jabra UC Voice 550 headset features crystal-clear wideband sound and HD Voice for voice calls and multimedia while the noise-cancelling microphone filters out ambient noise.
  • Designed for comfort
    The Jabra UC Voice 550 headset is designed for maximum comfort with soft leatherette padding on the headband and ear cushions.
  • Easy to deploy and operate
    The Jabra UC Voice 550 headset is certified and optimised for use with all major UC platforms, is USB plug-and-play ready and features simple call control through the in-line switch on the cord. All this equals stress-free deployment and fast user uptake.
  • Flexible boom-arm tip for optimal positioning
    The Jabra UC Voice 550 headset's flexible boom-arm allows you to position the microphone ideally for optimal voice clarity.
  • HiFi Sound
    Immerse yourself in music with hi-fi sound. Listen to flawless music reproduction across the entire audible frequency range.
  • UC Plug-And-Play
    Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
Jabra UC Voice 550 MS Duo - headset - USB
Headset - wired - USB
Recommended Use
Phone, computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
Microphone
Boom
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Software Certification
Certified for Skype for Business
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
In-Cord Volume Control
Adjustable Headband
PeakStop technology
Microphone
Boom
Headset microphone
Noise Cancelling
Remote Control
Controls
Connector Type
Headset (USB)
Carrying pouch
Cable Details
Headset cable
Plug and Play
7NL2 Jabra USB-A to USB-C Adapter In Stock £15.16
