Jabra Step
Jabra Step
Quicklinx: 9ZDMWS00 Mfr#: 100-97000000-60
Step Wireless allows you to give up the cords and listen to music, play games and take calls on the go in high quality stereo sound. With Step Wireless, you can leave your phone in your pocket and control your music and calls straight from your earbuds.
Get all of your music. These noise-isolating earbuds may be small but they pack impressive sound. They're angled to lock in immersive, full sound and your music won't skip a beat.
Step's earbuds are so light and comfortable, you'll forget they're there. Soft, flexible GelHooks ensure they fit naturally and securely in your ear. Dust and water resistant, Step is designed to keep up with your lifestyle.
  • Designed for life on the move
    Step's earbuds are so light and comfortable, you'll forget they're there. Soft, flexible GelHooks and a choice of three types of EarGels ensure they fit naturally and securely in your ear.
  • Great sound
    Get all of your music. These noise-isolating earbuds may be small but they pack impressive sound. They're angled to lock-in immersive, full sound and your music won't skip a beat.
  • Lifeproof
    Dust and water resistant, Jabra Step wireless is designed to keep up with your lifestyle.
Jabra Step Wireless - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics, computer
Headphones Form Factor
In-ear - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0 EDR
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 95 dB
Impedance
32 Ohm
Microphone
On-cable
Controls
Volume, answer/end, play/pause, next/previous track
1-year warranty
2 cm
2 cm
1.6 cm
16.5 g
Recommended Use
Protection
Waterproof, dust-resistant
Max Operating Distance
10 m
Audio Output
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
95 dB
Impedance
32 Ohm
Diaphragm
10 mm
Microphone
On-cable
Sensitivity
-42 dB
Frequency Response
100 - 10000 Hz
Audio Input Details
Omni-directional
Remote Control
Controls
Wireless Link
Transmission Range
10 m
Connector Type
USB (5 pin Micro-USB Type B (power only))
USB cable, 2 earhooks, 3 pairs of ear tips (small, medium, large)
Cable Details
Headset cable - 75 cm
GOST, IC, FCC, RoHS, REACH, IP52
Headset battery rechargeable
Run Time (Up To)
4 hour(s)
Standby Time
144 hours
Recharge Time
2 hour(s)
Limited warranty - 1 year
