Step Wireless allows you to give up the cords and listen to music, play games and take calls on the go in high quality stereo sound. With Step Wireless, you can leave your phone in your pocket and control your music and calls straight from your earbuds.
Get all of your music. These noise-isolating earbuds may be small but they pack impressive sound. They're angled to lock in immersive, full sound and your music won't skip a beat.
Step's earbuds are so light and comfortable, you'll forget they're there. Soft, flexible GelHooks ensure they fit naturally and securely in your ear. Dust and water resistant, Step is designed to keep up with your lifestyle.
Designed for life on the move
Step's earbuds are so light and comfortable, you'll forget they're there. Soft, flexible GelHooks and a choice of three types of EarGels ensure they fit naturally and securely in your ear. -
Great sound
Get all of your music. These noise-isolating earbuds may be small but they pack impressive sound. They're angled to lock-in immersive, full sound and your music won't skip a beat. -
Lifeproof
Dust and water resistant, Jabra Step wireless is designed to keep up with your lifestyle.
- Jabra Step Wireless - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics, computer
- Headphones Form Factor
- In-ear - over-the-ear mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.0 EDR
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 95 dB
- Impedance
- 32 Ohm
- Microphone
- On-cable
- Controls
- Volume, answer/end, play/pause, next/previous track
- 1-year warranty
- Product Type
- 2 cm
- 2 cm
- 1.6 cm
- 16.5 g
- Recommended Use
- Protection
- Waterproof, dust-resistant
- Max Operating Distance
- 10 m
Audio Output
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 95 dB
- Impedance
- 32 Ohm
- Diaphragm
- 10 mm
Microphone
- On-cable
- Sensitivity
- -42 dB
- 100 - 10000 Hz
- Audio Input Details
- Omni-directional
Remote Control
- Controls
Wireless Link
- Transmission Range
- 10 m
- Connector Type
- USB (5 pin Micro-USB Type B (power only))
- Included Accessories
- USB cable, 2 earhooks, 3 pairs of ear tips (small, medium, large)
- Cable Details
- Headset cable - 75 cm
- GOST, IC, FCC, RoHS, REACH, IP52
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 4 hour(s)
- Standby Time
- 144 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 1 year
