Your basket is empty
Jabra SPEAK410 USB Speaker MS
Quicklinx: 7C6SWS00 Mfr#: 7410-109
Recommended Use: Accessory
Connectivity: Wired
Earcover : [N/A]
30 in stock
£60.20 ex VAT
£72.24 inc VAT
Express delivery Order within the next 10 hours for delivery tomorrow
Jabra SPEAK 410 is a speakerphone designed for office professionals with everyday need for audio conferencing. Its compact design and travel case make it easy to carry around, and the integrated cable management ensures quick set-up. It's the perfect solution for spontaneous conferencing and collaboration.
Jabra SPEAK 410 MS is optimized for seamless integration with Microsoft Lync. Simply connect Jabra SPEAK 410 MS to your computer and you are ready to make your first call. The unique and intuitive on-device call controls allow you to adjust the volume, mute and even answer or end a call. The external ringer ensures that you never miss a call.
* Optimized for Microsoft® Lync™
* Intuitive on-device call controls
* Integrated cable management and travel case
* Headset port for private calls
Jabra SPEAK 410 MS - USB VoIP desktop hands-free
USB VoIP desktop hands-free - wired
Wired
Sound Output Mode
Mono
Microphone
Built-in
Microphone Operation Mode
Mono
Controls
Volume, answer/end
2 years warranty
Headphones
Wired
Sound Output Mode
Mono
Microphone
Mono
Audio Input Details
Omni-directional
Remote Control
Controls
Volume, answer/end
Connector Type
USB (4 PIN USB Type A) , Headset (mini-phone 3.5 mm 4-pole)
USB cable
Resources
The following resources are available for the Jabra SPEAK410 USB Speaker MS
Connectivity: Wired
Earcover : [N/A]
Brand: Jabra
Price Range Ex VAT: 50 - 100
