Increase productivity and stay focused wherever you are with Jabra SPEAK, a range of speakerphones that give you the ability to Collaborate and discuss business issues with perfect sound and simple set up. With Jabra, collaboration has never been easier.
PLUG-AND-PLAY SOLUTION
Plug your USB cable or connect via Bluetooth, and simply connect Jabra SPEAK to your PC, tablet or smartphone. That's it. You are ready to start talking.
OUTSTANDING SOUND QUALITY
To get crystal clear calls with natural conversation with no feedback or echo. Keep your conversations flowing to maximise your meeting time.
OPTIMAL USER EXPERIENCE
Benefit from full compatibility - including call control, with the leading UC/Softphone solutions and any Bluetooth enabled smartphone or tablet.
SLIM AND COMPACT DESIGN
Get the perfect solution for audio conferencing on demand with a compact and lightweight design, an integrated USB cable management for quick set-up.
Superior audio for larger conference calls
Unique ZoomTalk microphones ensure everyone is heard with up to 15 attendees. -
Premium UC experience
Set up in seconds with out of the box compatibility with all leading UC platforms. -
Seamless Connectivity
Get your meetings started quicker than ever via USB, Bluetooth or a 3.5 mm connection to laptops or smartphones.
- Jabra SPEAK 810 UC - speakerphone
- Product Type
- Speakerphone - Bluetooth - wireless - NFC - USB, 3.5 mm jack
- Recommended Use
- Portable electronics, computer - communication
- Additional Functions
- DSP, LED lights, USB charging port
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- Audio Specifications
- Frequency Response 100 - 20000 Hz - Sensitivity 80 dB
- Impedance
- 4 Ohm
- Max Input Power
- 6000 mW
- Microphones Included
- 6
- Controls
- Mute, volume, answer/end
- 2-year warranty
- Product Type
- 36 cm
- 18 cm
- 3.95 cm
- 965 g
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio Gateway Hands-Free Profile (AGHFP)
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- 100 - 20000 Hz
- Max Input Power
- 6000 mW
- Sensitivity
- 80 dB
- Impedance
- 4 Ohm
- Diaphragm
- 56 mm
- ZoomTalk technology
Microphone
- Form Factor
- Built-in
- 6
- Sensitivity
- -29 dB
- 20 - 8000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Audio Input Details
- - 20 - 8000 Hz
Remote Control
- Controls
- Connector Type
- USB 2.0 (4 PIN USB Type A) , Headset (mini-phone 3.5mm)
- Included Accessories
- Carrying pouch, charger
- Cable Details
- USB cable - 2.1 m , Audio cable - 1.2 m
- Plug and Play, CCC, IC, FCC, RoHS, KCC, TELEC, REACH, EAC, NCC, iDA, RCM, NTC, SIRIM, ETA, SDPPI
- Limited warranty - 2 years
- Shipping Width
- 36.6 cm
- Shipping Depth
- 45.6 cm
- Shipping Height
- 28.7 cm
- Shipping Weight
- 1.57 kg
Jabra USB-A to USB-C Adapter | In Stock | £14.99 |
Jabra Link 370 USB BT Adapter, MS Teams | In Stock | £53.21 |
