The Jabra Speak 510 is a portable speakerphone that gives you the power to turn any room into a conference room. Regardless of your location and your timeline, you can now join the conversation anytime, anywhere.
Slim and compact design
Get the perfect solution for audio conferencing on demand with a compact and lightweight design, an integrated USB cable management for quick set-up and a protective travel case.
Plug-and-play solution
Plug your USB cable or connect via Bluetooth®, and simply connect Jabra Speak to your PC, tablet or smartphone. That's it. You are ready to dial in.
Outstanding sound quality
To get crystal-clear and natural sounding calls that allow attendees to hear and speak clearly across any location.
Unlimited mobility
Choose Jabra Speak 510 enhanced with Bluetooth to connect to any mobile device and get the freedom to communicate on your terms.
Optimal user experience
Benefit from full compatibility - including call control, with the leading UC/Softphone solutions and any Bluetooth enabled cell phone, smartphone or tablet.
- Jabra SPEAK 510+ UC - speakerphone - USB
- Product Type
- Speakerphone - Bluetooth - wireless - USB
- Compatibility
- Windows
- Recommended Use
- Portable electronics, computer - communication
- Additional Functions
- DSP, LED lights
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Sound Output Mode
- Mono
- Sound Effects
- Crystal Clear
- Audio Specifications
- Frequency Response 250 - 14000 Hz
- Microphone Operation Mode
- Omni-directional
- Controls
- Mute, volume, answer/end
- Intelligent Assistant
- Siri, Cortana, Google Assistant
- 2-year warranty
- Product Type
- Compatibility
- Windows
- DSP, LED lights
- 12 cm
- 12 cm
- 3.3 cm
- 195 g
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio Gateway Hands-Free Profile (AGHFP)
- Sound Output Mode
- Mono
- Sound Effects
- Crystal Clear
- 250 - 14000 Hz
- Diaphragm
- 50 mm
- Simultaneously Connectable Devices Qty
- 2
- Voice guidance
Microphone
- Form Factor
- Built-in
- Omni-directional
- 150 - 6500 Hz
- Audio Input Details
- Omni-directional - 150 - 6500 Hz
Remote Control
- Controls
- Connector Type
- USB 2.0 (4 PIN USB Type A)
Cable
- Cable Length
- 90 cm
Internet of Things (IoT)
- Included Accessories
- Carrying pouch, Jabra Link 370 USB Adapter
- Cable Details
- USB cable - 90 cm
- Plug and Play, IC, FCC, KCC, TELEC, SRRC, NCC, RCM
- Battery
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 15 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
- Shipping Width
- 13.25 cm
- Shipping Depth
- 14.3 cm
- Shipping Height
- 4.55 cm
Jabra Secure Mount For Speak 410/510 | In Stock | £2.00 |
Jabra Link 370 USB BT Adapter, MS Teams | In Stock | £53.21 |
