Once your Jabra SPEAK has become a natural part of your way of communicating, it is very unfortunate if it is not available when you need it. The solution is to mount a Jabra SPEAK secure mount on the table.
Your Jabra SPEAK is easily mounted in the secure mount so subsequently it is difficult to remove it without the proper screwdriver . Of course you can always easily remove your Jabra SPEAK and take it with you when you need ultimate mobility.
