With Jabra PRO 9460 headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, the model is fitted with a flex boom for optimum voice pick-up. Jabra PRO 9460 is a single-ear headset that can be worn hooked over the ear, or on a head or neckband.The device is united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze.
One headset for all phones
Take every call on the same headset. Connects to your desk phone, mobile and softphone ? all at the same time. Manage multiple calls through an industry-first, user-friendly touch-screen or touchpad. Also comes with a SmartSetup wizard that guides you through the connection process. -
Outstanding sound quality
If you talk and listen for a living, clear conversations can make or break a deal. Get best-in-class noise-cancellation and acoustic protection. Your calls will sound great ? even in the noisiest of offices. Noise Blackout ?: Ear cushions and microphone are specially designed to eliminate background noise. Digital Signal Processing and HD Voice make your calls more intelligible and lifelike. SafeTone? technology automatically counters unexpected spikes in volume and protects your ears. -
True wireless freedom
Wireless DECT technology allows you to roam up to 150 metres away from your desk without dropping the call. Answer and end calls remotely while multitasking around the office. With up to 10 hours of battery life, you won?t need to worry about running out of charge. -
DECT security compliant
Compliant with the latest security requirements of the DECT standard, designed to safeguard against eavesdropping. The Jabra-patented headset-to-base pairing process avoids risky pairing over the air to protect your conversations. -
10-Hour Battery Life
Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
- Jabra PRO 9460 - headset
- Product Type
- Headset - wireless - DECT
- Recommended Use
- PC multimedia, corded phone, mobile phone
- Localisation
- Hong Kong, Singapore, United Kingdom
- Headphones Type
- Headphone - monaural
- Headphones Form Factor
- Convertible
- Connectivity Technology
- Wireless - DECT
- Sound Output Mode
- Mono
- Frequency Response
- 150 - 6800 Hz
- Microphone
- Boom
- 2 years warranty
- Product Type
- Headset - DECT
- 31 g
- Recommended Use
- Noise cancelling circuit, mute button, answer/end button, volume control, touch sensor operation, built-in DSP, PeakStop Technology, Jabra SafeTone technology
- Localisation
Headphones
- Headphones Type
- Convertible
- Wireless - DECT
- Sound Output Mode
- Mono
- 150 - 6800 Hz
Microphone
- Boom
Wireless Link
- Transmission Range
- 150 m
- Cables Included
- 1 x USB cable - external , 1 x phone cable - external
- Included Accessories
- Neck strap, headband, power adapter, base station, headset charging cradle, earhook
- EN 60950, UL 60950, IEC 60950-1
- Battery
- Headset battery - rechargeable
- Included Qty
- 1
- Run Time (Up To)
- 10 hour(s)
- Standby Time
- 46 hours
- 2 years warranty
- Service & Support Details
- Limited warranty - 2 years
Jabra Electronic Hook Switch Cable | In Stock | £39.96 |
Jabra LINK EHS-Adapter For Cisco 6945 78xx/79xx/88xx Desk Phones | In Stock | £39.96 |
