Jabra PRO 9450 Mono Midi Boom Spare Headset
Quicklinx: 8HHMWS00 Mfr#: 14401-07
The Jabra PRO 9450 dual connectivity headset is a user-friendly, no-frills device which provides office staff with a straightforward interface to handle calls from both desk phones and UC softphones. It is therefore ideal for companies in transition to UC, or indeed any organization using a combination of these two types of phones. With Jabra PRO 9450, everyone has an opportunity to benefit from true wireless working and enhanced productivity!
  • Exceptional audio clarity
    With a frequency response of 150 - 6800 Hz and Noise Blackout technology, the Jabra PRO 9450 Replacement headset ensures every conversation is heard with clear clarity, whether in a noisy office or a quiet room.
  • Wireless freedom
    DECT wireless technology provides a robust connection with up to 150 m operating distance, offering the freedom to move around the office without losing call quality.
  • All-day comfort
    Designed for prolonged use, the on-ear headphones with a 28 mm diaphragm are lightweight and comfortable, ensuring you can focus on your calls without discomfort.
  • Advanced call management
    Equipped with intuitive controls for answer/end, mute, and volume directly on the headset, managing calls is seamless, enhancing productivity and convenience.
  • Long-lasting battery life
    The rechargeable battery offers up to 38 hours of standby time and can be fully recharged in just 2 hours, ensuring the headset is ready when you are.
Jabra PRO 9450 Replacement - headset - replacement
Headset - replacement - DECT - wireless
Recommended Use
Portable electronics, phone, computer - communication
Additional Functions
DSP
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 6800 Hz - Sensitivity 93 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Boom
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
PRO 9450, 9450 Duo, 9450 Duo NCSA, 9450 Flex
Headset - DECT - wireless
Replacement
DSP
4.8 cm
13 cm
1.8 cm
28 g
Recommended Use
Max Operating Distance
150 m
Audio Output
On-ear
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Active Noise Cancelling Technology
Noise Blackout
Frequency Response
150 - 6800 Hz
Sensitivity
93 dB
Impedance
32 Ohm
Diaphragm
28 mm
SafeTone technology, PeakStop technology
Microphone
Boom
Headset microphone
Sensitivity
-30 dB
Frequency Response
150 - 6800 Hz
Noise Cancelling
Audio Input Details
Uni-directional - 150 - 6800 Hz
Remote Control
Controls
Plug and Play, UL, NOM, CB, IC, PSB, FCC, TELEC, EAC, ICASA, NTC, ACMA, SIRIM
Headset battery rechargeable
Run Time (Up To)
10 hour(s)
Standby Time
38 hours
Recharge Time
2 hour(s)
Jabra PRO 9450, 9450 Duo, 9450 Duo NCSA, 9450 Flex
