The Jabra Pro 920 headset is a professional wireless headset designed for maximum performance. Now everyone in your office can take advantage of the added productivity and comfort that wireless convenience delivers. Simple, intuitive and high quality, all-in-one wireless solution.
With the DECT wireless technology you get up to 120 metres hands-free communication for your deskphone. Talk for up to 8 hours with no battery life concerns.
Wireless headset range
Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants).
World-class sound
Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both - and choose between a range of mono and duo variants.
Easy to use with all-day battery
The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out.
Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants). -
World-class sound
Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both – and choose between a range of mono and duo variants. -
The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out. -
8-Hour Battery Life
Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience. -
UC Plug-And-Play
Jabra's intelligent Call Assist lets you take a call without a click. Built-in motion sensor technology turns the headset on when you pick it up or touch it, and automatically answers the call when you place it on your ear. If you are already wearing the headset, you can accept or reject a call using just your voice.
- Jabra PRO 930 MS - headset
- Product Type
- Headset - DECT - wireless
- Localisation
- Hong Kong, Singapore, United Kingdom
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT
- Sound Output Mode
- Mono
- Microphone
- Boom
- Controls
- Mute, volume, answer/end
- 2 years warranty
- Product Type
- Headset - DECT
- 27 g
- Max Operating Distance
- 120 m
- Localisation
Headphones
- Supraaural
- Wireless
- DECT
- Sound Output Mode
- Mono
Microphone
- Boom
Remote Control
- Controls
Wireless Link
- Transmission Range
- 120 m
- Cables Included
- USB cable
- Plug and Play, EN 60950, UL 60950, IEC 60950-1
- Battery
- Headset battery rechargeable
- Included Qty
- 1
- Run Time (Up To)
- 6 hour(s)
- Standby Time
- 36 hours
- Limited warranty - 2 years
Jabra GN9300, PRO and GO Unit Power Supply Unit | In Stock | £15.91 |
Jabra PRO 900/9400 Neckband | In Stock | £12.77 |
Jabra PRO 900 and 9400 Series Earhook | In Stock | £6.29 |
Jabra Pro 900 Series Mono Headset (Top Only) | In Stock | £84.08 |
Jabra PRO 900 Series Headband | In Stock | £13.12 |
Jabra Mini USB Cord For PRO 900 | In Stock | £15.91 |
