It's a professional wireless headset that comes with your choice of connectivity possibilities and a pre-connected base. A simple, reliable and affordable way to go wireless - wherever you work.
Wireless headset range
Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants). -
World-class sound
Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both – and choose between a range of mono and duo variants. -
Easy to use with all-day battery
The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out.
- Jabra PRO 930 Duo MS - headset
- Product Type
- Headset - DECT CAT-iq - wireless
- Recommended Use
- Phone
- Additional Functions
- LED lights
- Localisation
- Hong Kong, Singapore, United Kingdom
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT CAT-iq
- Radio Frequency Range
- 1.88 - 1.9GHz, 1.92 - 1.93GHz
- Microphone
- Boom
- Controls
- Mute, volume control, answer/end
- Product Type
- LED lights
- 7.6 cm
- 2.9 cm
- 11.8 cm
- Recommended Use
- Phone
- Max Operating Distance
- 120 m
- Localisation
Audio Output
- On-ear
- Wireless
- DECT CAT-iq
Microphone
- Boom
Remote Control
- Controls
Wireless Link
- Transmission Range
- 120 m
- Connector Type
- USB
- Included Accessories
- Base stand
- Cable Details
- USB charge cable
- Battery
- Headset battery rechargeable - lithium polymer
- Capacity
- 295 mAh
- Run Time (Up To)
- 8 hour(s)
- Standby Time
- 36 hours
- Recharge Time
- 3 hour(s)
