Jabra Pro 920 Wireless Headset - Deskphone Only
Quicklinx: 7VKJWS00 Mfr#: 920-25-508-102
Recommended Use: Corded phone
Connectivity: Wireless
Earcover : Monaural
Select:
12 In Stock
£128.46 ex VAT
£154.15 inc VAT
The Jabra Pro 920 headset is a professional wireless headset designed for maximum performance. Now everyone in your office can take advantage of the added productivity and comfort that wireless convenience delivers. Simple, intuitive and high quality, all-in-one wireless solution.
With the DECT wireless technology you get up to 120 metres hands-free communication for your deskphone. Talk for up to 8 hours with no battery life concerns.
Wireless headset range
Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants).
World-class sound
Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both - and choose between a range of mono and duo variants.
Easy to use with all-day battery
The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out.
  • Wireless headset range
  • World-class sound
    Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both – and choose between a range of mono and duo variants.
  • Easy to use with all-day battery
  • 8-Hour Battery Life
    Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
Jabra PRO 920 - headset
Headset - DECT - wireless
Hong Kong, Singapore, United Kingdom
Headphones Form Factor
Convertible - monaural
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume, answer/end
Max Operating Distance
120 m
Audio Output
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
Wireless Link
Transmission Range
120 m
Connector Type
Headset (RJ-9) , Phone line (RJ-9) , AUX input (RJ-45)
Base unit
Cable Details
Phone cable
Plug and Play, EN 60950, UL 60950, IEC 60950-1
7VKJ Jabra Pro 920 Wireless Headset - Deskphone Only In Stock £128.46
7VKJ Jabra Electronic Hook Switch Cable In Stock £30.21
7VKJ Jabra LINK EHS-Adapter For Cisco 6945 78xx/79xx/88xx Desk Phones In Stock £30.96
Resources
The following resources are available for the Jabra Pro 920 Wireless Headset - Deskphone Only
Earcover : Monaural
Brand: Jabra
