The Jabra PRO 900 DECT variants gives you the wireless freedom to walk and talk at up to 120 meters of range or 100 meters for Bluetooth variants.
Never miss a word of what's being said. Enjoy crystal clear conversations with high definition sound. Protective features like SafeTone cut off loud noises and protects your hearing.
Jabra PRO 900 is easy to set up and get started with. Each headset comes with a pre connected base so you can make calls straight away.
Wireless headset range
Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants). -
World-class sound
Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both – and choose between a range of mono and duo variants. -
Easy to use with all-day battery
The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out. -
8-Hour Battery Life
Multi-device connectivity technology lets you manage phone calls from several different devices such as deskphones, tablets, PCs and smartphones, with one single headset. You get greater flexibility and enhanced user experience.
 - Jabra PRO 920 Duo - headset
- Product Type
 - Headset - DECT - wireless
- Recommended Use
 - Phone
- Localisation
 - Hong Kong, Singapore, United Kingdom
- Headphones Form Factor
 - On-ear - convertible
- Connectivity Technology
 - Wireless
- Wireless Technology
 - DECT
- Sound Output Mode
 - Stereo
- Microphone
 - Boom
- Controls
 - Mute
- Product Type
 - 27 g
- Recommended Use
 - Phone
- Max Operating Distance
 - 120 m
- Localisation
Audio Output
 - Wireless
 - DECT
- Sound Output Mode
 - Stereo
Microphone
 - Boom
Remote Control
- Controls
 - Mute
Wireless Link
- Transmission Range
 - 120 m
- Included Accessories
 - Power adapter, base station
- Battery
 - Headset battery rechargeable
- Included Qty
 - 1
- Run Time (Up To)
 - 8 hour(s)
- Standby Time
 - 36 hours
