A central unit which connects Jabra PanaCast and Jabra Speak to your computer with just one cable.
Versatile connectivity
Equipped with a wide range of ports including HDMI, VGA, Ethernet 1000Base-T, and SuperSpeed USB 3.0, the Jabra PanaCast USB Hub ensures seamless connection options for various devices and peripherals, enhancing productivity and user experience. -
High-resolution support
The Jabra PanaCast USB Hub supports a maximum resolution of 3840 x 2160 at 30 Hz, providing clear and detailed visuals for an immersive viewing experience on connected displays. -
Integrated cable design
With an integrated 1 m USB-C cable, the Jabra PanaCast USB Hub offers a tidy and efficient setup, reducing clutter and simplifying connectivity. -
Efficient power delivery
The docking station comes with a power adapter capable of providing 45 watts, ensuring that connected devices are charged and ready for use without the need for multiple power sources. -
Compliant with standards
Adhering to the USB Battery Charging Specification Rev. 1.2, the Jabra PanaCast USB Hub ensures safe and efficient charging, enhancing device longevity.
 - Jabra PanaCast USB Hub - docking station - USB-C - VGA, HDMI
- Product Type
 - Docking station
- Docking Interface
 - USB-C
- Video Interfaces
 - VGA, HDMI
- Localisation
 - United Kingdom
- Power
 - Power adapter 45 Watt Power Provided
- Product Type
 - Docking station
- Localisation
 - United Kingdom
Video
- Max Resolution Details
 - 3840 x 2160 - 30 Hz
 - 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x video - VGA - 15 pin D-Sub (DB-15) , 1 x network - 1000Base-T - RJ-45 , 1 x SuperSpeed USB 3.0 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C - 24 pin USB-C , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
- Cables Included
 - 1 x USB-C cable - integrated - 1 m
 - USB Battery Charging Specification Rev. 1.2
- Power Device
 - Power adapter
- Power Provided
 - 45 Watt
