Connect your PanaCast 50 over longer distances, for example in larger rooms, with the 5m USB 2.0 USB-C to USB-A cable.
Efficient connectivity
The Jabra USB-C cable offers a seamless connection between devices, featuring a male 24-pin USB-C on one end and a male 4-pin USB Type-A on the other. This design ensures compatibility with a wide range of devices, facilitating easy and efficient data transfer and charging. -
High compatibility
Compliant with USB and USB 2.0 standards, this cable is designed to meet the current connectivity needs. Its adherence to these standards ensures a reliable connection between devices, ensuring that data transfers are both fast and secure.
- Jabra - USB-C cable - 24 pin USB-C to USB - 5 m
- USB-C cable
- Length
- 5 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Designed For
- PanaCast 50
- USB-C cable
- Length
- 5 m
- Connector
- USB / USB 2.0
- Designed For
- Jabra PanaCast 50
