Jabra PanaCast USB Cable USB 2.0 5m USB C to USB A
Quicklinx: GGJBWS00 Mfr#: 14202-11
Length: 5m
Hurry, only 1 left in stock!
£34.01 ex VAT
£40.81 inc VAT
Connect your PanaCast 50 over longer distances, for example in larger rooms, with the 5m USB 2.0 USB-C to USB-A cable.
  • Efficient connectivity
    The Jabra USB-C cable offers a seamless connection between devices, featuring a male 24-pin USB-C on one end and a male 4-pin USB Type-A on the other. This design ensures compatibility with a wide range of devices, facilitating easy and efficient data transfer and charging.
  • High compatibility
    Compliant with USB and USB 2.0 standards, this cable is designed to meet the current connectivity needs. Its adherence to these standards ensures a reliable connection between devices, ensuring that data transfers are both fast and secure.
Jabra - USB-C cable - 24 pin USB-C to USB - 5 m
USB-C cable
Length
5 m
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
PanaCast 50
USB-C cable
Length
5 m
Connector
24 pin USB-C - male
USB / USB 2.0
Jabra PanaCast 50
Length: 5m
Brand: Jabra
