Jabra Motion UC+ Bluetooth Headset - Travel & Charge Kit
Quicklinx: CLHLWS00 Mfr#: 6640-906-100
The Jabra Motion UC's intuitive controls, motion sensing technologies, quick NFC pairing and incredible 100 metres range from the PC, make it a smart, stylish choice for mobile professionals. Comes with a compact charging kit that doubles as a carrying case for easy storage.
A high-end Bluetooth headset features excellent intelligent technology that allows you to communicate easily, both in the office and on the go.
Jabra Motion is second to none in terms of innovative features and future proof technology. Designed for maximum convenience and providing superior wearing comfort, it helps simplify your busy lifestyle. It is the only headset you'll ever need. Built-in motion sensors reacts to your movements and different sound environments, enabling intuitive call control, unsurpassed battery performance and superior audio quality.
  • Superior sound
    Get best-in-class sound quality. Built-in motion sensor and advanced microphones adapt the sound to your surroundings. Enjoy crystal-clear, high-definition calls even in noisy or windy conditions.
  • All-day comfort
    Get maximum comfort with a behind-the-ear design and flexible materials that hug your ear. Find the perfect fit by adjusting the speaker and flipping it to fit either ear.
  • Smart motion sensor
    Answer calls by simply picking up the headset. When lying still, the motion sensor activates a "Power Nap" mode to save battery. Lift the headset, and it's ready to go again.
Jabra Motion UC+ - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics, computer
Headphones Form Factor
Ear-bud - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Mono
Active Noise Canceling
Microphone
Boom
Controls
Mute
17.5 g
Recommended Use
Max Operating Distance
100 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Mono
Active Noise Cancelling Technology
Noise Blackout
Microphone
Boom
Remote Control
Controls
Mute
Wireless Link
Transmission Range
100 m
Bluetooth USB adapter, charging case, 3 pairs of gel ear tips
Cable Details
USB cable
Headset battery rechargeable
Included Qty
1
Run Time (Up To)
7 hour(s)
Standby Time
360 hours
CLHL Jabra USB-A to USB-C Adapter In Stock £12.40
