The Jabra Pro 900 Mini USB cable is a spare cable that provides a micro USB to USB connection. It is specifically designed to fit with Jabra Pro 900 Wireless Headset.
Effortless connectivity
Equipped with a USB cable, this Jabra headset ensures a seamless connection to your devices. The inclusion of both a 4-pin USB Type-A and a 4-pin mini-USB Type-B connector supports versatile use with a wide range of electronics, making it an ideal choice for users seeking reliable and easy-to-manage connectivity options. -
Designed for compatibility
This headset's design focuses on compatibility, featuring a male to male connection that facilitates straightforward, hassle-free setup. Whether connecting to a computer, laptop, or other USB-enabled device, users will appreciate the simplicity and efficiency this design offers.
- Jabra - USB cable - USB to mini-USB Type B - 1.5 m
- USB cable
- Length
- 1.5 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin mini-USB Type B - male
- Designed For
- Jabra GN9330 USB, GN9330 USB for Microsoft Office Communicator 2007, GN9350
- USB cable
- Length
- 1.5 m
- Connector
- Designed For
