Jabra Mini is definitely a tiny headset, but in no way does it compromise on sound quality for the sake of being small. Jabra Mini puts hands free communication in the palm of your hand and crystal clear audio in your ear with the tried and tested HD Voice technology.
The compact design of this tiny Bluetooth headset does not put a limit to the functionality of Jabra Mini. With the three intuitive buttons you can do everything you need - turn the headset on/off, answer or reject calls, and control the volume too. Jabra Mini also comes with voice guidance to notify you of the connection status to your device and when you need to recharge your headset.
Quality comfort - all day, every day
Jabra Mini has been designed for all-day hands-free wearing and offers two wearing style options - with EarGels or the earhook. -
The power nap to keep you going
Jabra Mini can automatically extend its battery power with the Power Nap feature. The headset turns itself off after having been disconnected from your device for a full hour. -
Wear it all day
The Jabra Mini also comes with voice guidance to notify you of the connection status to your device and when you need to recharge your headset. -
Jabra Mini Outdoor Edition: Featuring the Realtree Xtra pattern
Crafted for the outdoor lifestyle, the Jabra Mini Outdoor Edition boasts the official Realtree Xtra pattern. Building on Realtree 's 30 years of experience, it frees your hands so you can enjoy more of the great outdoors. -
QUALITY COMFORT - ALL DAY, EVERY DAY
THE POWER NAP TO KEEP YOU GOING
JABRA MINI OUTDOOR EDITION: FEATURING THE REALTREE XTRA PATTERN
- Jabra Mini - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Headphones Form Factor
- In-ear - convertible - monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Mono
- Microphone
- Built-in
- Controls
- Mute, volume, on/off, answer/end
- Product Type
- 1.47 cm
- 4.71 cm
- 0.99 cm
- 10 g
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Mono
- Diaphragm
- 11 mm
Microphone
- Audio Input Details
- Omni-directional
Remote Control
- Controls
Wireless Link
- Transmission Range
- 30 m
- Connector Type
- USB (mini-USB Type A)
- Included Accessories
- 2 earhooks, 2 gel ear tips
- Cable Details
- USB charge cable
- Battery
- 1 x headset battery rechargeable
- Included Qty
- 1
- Run Time (Up To)
- 9 hour(s)
- Standby Time
- 216 hours
